Problems importing *.stp
All  1-16  17-20
4312.17 In reply to 4312.15
Geez... this whole thing is becoming a nightmare... the paw is from a pdf (vector) from the mfg. that I projected (direction) to the surface you created earlier. I then trimmed > extruded > exported to *.stp and iserted into an earlier version of my 123D file (pre-paw) Everything worked great up to this point. I then constrained (tangent assembly constraint) the paw to the spot it was located (worked great, bing-bang-boom). If it's any consolation, 123D would not boolean them together either. I thought it was a shortcoming of 123D so I exported (both bodies as constrained) to *.stp and opened in MoI. Here we sit.
I guess I should start over with tracing the pdf with some new curves...
At least the body imported correctly this time... ;-)
8 GB RAM, ATi Radeon HD 3870
4312.18 In reply to 4312.13
But next time around for something similar probably try to make the pieces push through each other a little bit instead of having them kind of skimming right along each other. Either that or try to get the exact same surface in the areas that are coincident instead of having one rotated or fragmented differently than the other.
Having them push through a bit tends to be easiest, since it then doesn't make too much difference exactly how the bottom pieces are structured since they will get sliced off anyway.
4312.19 In reply to 4312.17
Hi Nick, well I was actually able to get the pieces unioned together in MoI (using Trim + Join method described above), so if you're just looking for a solid result of what you had that's attached above.
But yeah it's good to be kind of wary of PDF data - often times PDF files are really set up just for printing and not really as a source of 3D geometric calculations in mind.
There are quite a lot of things that can be ok for printing but bad for 3D modeling.
Also if the PDF file was generated from one of those PDF printer drivers, those tend to fragment things that were originally curves into a bunch of lines, since that is pretty common for an application to only actually send lines to a printer. So that's why you may rather often see PDFs that have have only polylines with a dense number of line segments in them rather than actual smooth curves...
EDITED: 1 Jun 2011 by MICHAEL GIBSON
4312.20 In reply to 4312.19
Heh... I found out 123D will and does boolean them. I was selecting the parent of the paw instead of the individual blocks in the browser... Apparently it's something they are fixing. Anyway, if I select each solid piece of the paw it booleans fine. The problem however still lies with exporting to *.stp where virtually every program broke it back into individual blocks that need to be booleaned again... I've learned my lesson with pdfs.
Show messages: All  1-16  17-20
