Fillet formula for degrees
All  1  2-6
4260.2 In reply to 4260.1
Hi Bob, you mean for chamfering?
There is one tutorial that Danny did that uses a formula for chamfering here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2662.6
The video tutorial is here:
http://cid-30cffdfa97399495.skydrive.live.com/self.aspx/.Public/Accurate|_Tapers|_MoI|_V2.zip
There's also a similar thing about using a formula to determine the offset distance to use to get a particular draft angle, check out these posts for that one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=941.5
http://moi3d.com/forum/index.php?webtag=MOI&msg=941.6
That second one uses Offset + Loft to make a result with a particular draft angle, and the formula gives you the offset distance required to match a particular angle.
Let me know if neither of those is what you were after.
4260.3 In reply to 4260.2
Good Evening, Michael...
Thanks for the info, and yes, I did mean chamfering. I knew it was in some tutorial that I had seen. I continue to use MOI for designing my line of horseshoes. I'm currently evaluating a series of 6 designs that I call my "Tribute" series. It honors all of the 5 military services and the Vietnam Veteran. I haven't found a single thing that I've wanted to do that MOI couldn't handle. I'm having a great time with sweeps and lofts, fillets and chamfers, etc. If there was one thing that I would add to my wish list, it would be a dialog that allowed me to make a few notes to tag along with my files. I have over 500 files that reflect various stages during the design process and it's difficult to name them uniquely for meaning.
Thank you for a wonderful piece of software. Regards...Bob
4260.4 In reply to 4260.3
Hi Bob.
As a temporary solution, remember that for windows files, you can right click the file and choose properties, then there is a "summary tab" where you can insert information and comments.....
I'll take a look and see if it is easy for me to create something that can access this info and help for this type of organization...
But maybe Michael will add something like this to the wishlist also...
4260.5 In reply to 4260.4
Hi Bob & Burr, I've added that to the wiki wishlist here: http://moi3d.com/wiki/Wishlist
4260.6 In reply to 4260.3
You could use M-files for file management. There is an express version that is free and gives full versioning and vault (check in/out) capabilities but is limited to 1000 files (I think).
http://www.m-files.com/eng/express_free.asp
8 GB RAM, ATi Radeon HD 3870
Show messages: All  1  2-6
