Menu Align &...
 1-16  17-22
4241.17 In reply to 4241.16
Hi Pilou, so the way a regular "distribute" function would work is that you would first need to roughly arrange those plates to stack them along the z axis direction. Then you could run the distribute function to get them equally spaced.
But the regular kind of distribute function only adjusts objects from their current locations to be exactly spaced, it is not normal for that kind of function to completely re-arrange things like take a 2D flat grid of objects and then transform that to be a single stack in a different direction - that would be a different kind of distribute function.
4241.18 In reply to 4241.16
Hi Pilou, also there is a plug-in that I wrote called MoveSliceToPoint which can be used to help with arranging a number of slices to equal spaces, it is here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2749.36
That's a different kind of thing than how a "Distribute" function works in a 2D illustration program though.
4241.19 In reply to 4241.18
Ah! I have forgotten this very useful one!
Maybe a day a little complet list of all
scripts + a little image will be necessary
because profusion of scripts becomes gorgeous!
In any case a space function will be useful for some tricky cases :)
EDITED: 4 May 2011 by PILOU
Ps The beauty of your your plug (moveSliceToPoint)
is that points can have different vertical positions and not a just on a straight line! Even any position in the 3D Space!
So very cool for boats' stations for example ;)
PSS and the more funny!
You can move at any time the profils not used before the next right click !!!
And also select more then one profile in the same time!
Like at the funfair ;)
And the MoveSliceToPoint works also for any Type of objects (curves, surfaces, volumes...) ;)
EDITED: 5 May 2011 by PILOU
Show messages:  1-16  17-22
