Points Lines
All  1-3  4-8
4183.4 In reply to 4183.3
Michael not sure if you are familiar with Spiro by Raph Levien ...very interestin :0 http://levien.com/phd/LevienSequinCAD09_014.pdf
I wish we could license his library...
4183.5 In reply to 4183.4
Oops my apologies, I should have search the forum before I post...I see Levien's work has been mentioned before.
4183.6 In reply to 4183.3
"""""""""""This would be particularly useful for drawing airfoil sections, which are (historically) defined by two lines intersecting given coordinates and a leading edge radius.""""""""""""""
Do you know that Michael added a "Conic curve" command? he also added an RHO value input to it.... FYI.
4183.7 In reply to 4183.3
Hi Hamish, yup like Burr says try the Conic command for a traditional airfoil curve.
It's available under Draw curve > More > Conic, and it lets you draw 3 points to make a shoulder bracket of 2 intersecting lines, and then either pick a point for the curve to go through or enter a "rho" value.
Some more information here:
http://moi3d.com/2.0/docs/moi_command_reference2.htm#conic
4183.8 In reply to 4183.4
Hi adam,
Yup, I wish so too, it's pretty cool!
I've tried to contact the author about commercial licensing, and unfortunately it appears that he does not have enough time and/or interest right now to do that.
In the future I want to experiment with some ideas on interpolation with a minimization in curvature changes that may give a kind of similar effect.
Show messages: All  1-3  4-8
