spiral on sphere...
All  1-2  3-12
4084.3
Hi Rainer,
The method Michael mentions is the way to go, here's a quick run-down for you and anyone else who's interested.
Create a regular Helix, 'Draw curve > More > Helix'
Draw a line (Green) perpendicular from the start of the Helix to the centre.
Sweep the Green line along the Helix 'Construct > Sweep' and use 'Flat' in the Twist option drop down.
Create a Sphere 'Draw Solid > Sphere' from the centre of the helix and use the end point of Helix for the size.
Then use 'Construct > Curve > Isect' to create an intersection curve between the Sphere and Swept surface, and you have what I call a 'HeliSphere'
Then have fun with it!
4084.4 In reply to 4084.3
Hey Danny, that turned out better around the pole area than I thought it might, cool!
4084.5
Yeah Michael, I was happy with it too!
The curve is good as is, but further refining with 'rebuild' and you get a nicer curve with evenly spaced control points.
4084.6 In reply to 4084.3
Danny,
How did you cut the curve perpendicular to the surface in the rendered example?
David
4084.7 In reply to 4084.3
Hi Danny,
Thanks for this Tip, very handy to know.
regards Colin
4084.8 In reply to 4084.6
Hi David,
I actually swept an arc profile which is the same radius as the sphere (in blue) to get the result in the rendered picture.
Is this what you mean?
Magic sweep! ;)
4084.10
Thanks Danny,
I did not realize it would track the spiral perpendicularly. I assumed you were doing something more exotic.
- David
4084.11 In reply to 4084.10
During the sweep you can fix or not the twist (free or fixed) ;)
4084.12 In reply to 4084.11
Ah yes... Thanks Frenchy Pilou.
Show messages: All  1-2  3-12
