Request: Random selection
A little script can make this?
Give from a type selection--> a random selection?
Some object selected ---> select only ~ 30% objects
Some faces selected---select only ~ 35 % faces
Some curves selected --> select only ~ 40% selected
etc
% can be of course any %
A random lenght extrude from a multiple selection?
3927.2 In reply to 3927.1
Hi Pilou, here's a script that can do the random selection part:
script: /* Deselect random objects */ var percent = 30; var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { if ( Math.random() * 100> percent ) objs.item(i).selected = false; }
You can change the value for the percent = 30 part in the script to adjust keeping more or fewer objects selected when it is triggered.
It won't give you exactly 30% of objects to remain selected, because it goes just object by object and gives each object by itself a 30% chance of remaining selected. But it should give a result somewhere close to 30% of the objects remaining selected.
3927.3 In reply to 3927.2
Works like a charm!
You can apply a fonction, reselect the random selection and re apply a random selection etc ;)
so you can obtain a chaotic result ;)
Many THX :)
And works fine for any types, curves, surfaces etc... ;)
EDITED: 22 Dec 2010 by PILOU
3927.4 In reply to 3927.3
Interesting stuff there Pilou, you might also be interested in this http://structuresynth.sourceforge.net/index.php
3927.5 In reply to 3927.4
yes but need some little effort of little scripting ;)
