Honeycomb pattern on dome shape
 1-4  5-24  25-34
3786.5 In reply to 3786.4
Thanks Michael. Yes, I figure I'll just have to experiment and see what works best.
-Jesus
3786.7
I think Pilou has a good hint there, there is a hex dome here for example:
http://sketchup.google.com/3dwarehouse/details?mid=d63037b783145b7e2137e32e8ebf2b1&prevstart=0
You can import data from a polygonal (obj.) file in moi with this utility:
http://kyticka.webzdarma.cz/3d/moi/#importobj
There is a couple of sketchup->obj plugins available I think...
Nice subject!
Marc
3786.8 In reply to 3786.7
>>I think Pilou has a good hint there, there is a hex dome here for example:<<
That is a mixture of 5 and 6 sided which is easy to construct. The OP wants all 6 sided, which cannot be constructed if the 6 sided need to maintain correct shape/ size.
- Steve
3786.9 In reply to 3786.7
Dont not forget best polymodeler Wings3d
and this tutorial for self made:
http://home.comcast.net/~chronosphere/tut-wings-bucky.htm
(plugin (geodome) from the tutorial are included in the latest version Wings3d)
after you can use tool "Importobj" recommended by Marc
or "ObjTo3dm" : http://dave-l.com/grafix/index.php?page=objto3dm
EDITED: 24 Sep 2010 by EDDI
3786.10 In reply to 3786.9
Hi eddi,
That's probably not going to work since it looks like it creates polygon mesh objects in the 3DM file and not NURBS objects.
MoI only reads NURBS objects from 3DM files and skips over other kinds of object types like spotlights, dimensions, polygon meshes, etc....
3786.11 In reply to 3786.10
Yes, Michael you are right,
it is known, Moi and polygon does not go.
But both tools bring lines from polygons (created in Wings3d) in to Moi.
Both tools offer a different alternative.
Obj23dmWireframe = separate line segments, filesize larger
EDIT:
HE
***ObjTo3dm = closed line segments, filesize smaller, no luck import geometry with polys less than 5 sides
Best alternative for geodome could be Grasshopper, in continuous honeycomb geometry.
http://api.ning.com/files/tNXd3jNkkDzdZmhUQDh7YDdlF2KdESpiSaTFPw8Pu06N5PtTrbnbBpxirrXxEQlj/CUPULOO8.JPG
3786.12 In reply to 3786.11
Hi Eddi,
It sounded like the main goal of that other converter was to make a mesh object in Rhino, but mesh objects in Rhino are limited to 3 or 4 sided polygons.
So it looks like when possible (< 5 sides) that program will convert to mesh objects in the 3DM file.
But that's interesting that it makes a closed polyline for each face that cannot be directly converted into a Rhino mesh object.
3786.13 In reply to 3786.12
Trick in Wings3d,
select edges, use cut(RMB) through 2, export as obj, (colors not correct converted)
In Objto3dm activate under options "convert NURBS to polygons"
Import in moi as closed polylines.
-EDDI
3786.14 In reply to 3786.1
hi jesus here is a way how to do it :
1 : create cylinder and sphere and bloon-union, trim with red line to make just half (surface sim should be where the red line is), shrink surface,
make blue lines where the end controlpoints is .
make green lines lenght =~= half Circumference off cylinder ( yelow curve )=( 3.14 x D) / 2
flaten the surfaces :
move end controllpoints off surfaces to end off green lines
trime with hexsagone pattern
move back the the end controllpoints and you should get good shape
EDITED: 2 Oct 2010 by BLYESS
3786.15 In reply to 3786.14
Amazing trick lyes, thanks to share it !!!!
3786.16 In reply to 3786.14
Very clever technique lyes! well done.
3786.17
Hi all here another trick : make patch with 1 or more cpts in the midel trim with a pattern scale rotate move the midel cpts or extract curves
thank you
Vasarely revival :)
http://www.vasarely.com/
3786.19 In reply to 3786.18
Hi Pilou thanks for the link I didn't know about this artist but I have seen panels like that and I was wondering how is than
I suppose creating curves like this we can call it VASARELY.
3786.20
Thanks Lyes
love the honeycomb pattern solution. Really helpful.
Jamie
@ Lyes
Sure you have made a pure Moi's Vasarely :)
A famous one by Vasarely:)
3786.22 In reply to 3786.21
ouch - that hurt my eyes.
What you see is what you believe - so don't. (from an Amiga500 demo)
3786.23 In reply to 3786.17
Hi Lyes,
I'm not sure if stupid questions are allowed in this forum? :-) but here goes.
How do you make a patch with these extra points?
I've tried adding points to a plane, with no luck.
Kind Regards
Charles
"There are three kinds of people in this world, those that can count, and those that can't"
3786.24 In reply to 3786.23
Just draw the crosshatching lines and run "Network" on them.. The resulting surface will have the point structure of the hatch.
Show messages:  1-4  5-24  25-34
