purge unused layers
All  1  2-6
3774.2 In reply to 3774.1
Hi okapi, here's a script that should do it. Add in a new shortcut key and paste in the following for the Command part:
script:var gd = moi.geometryDatabase; var styles = gd.getObjectStyles(); var counts = new Array(styles.length); for ( var i = 0; i < counts.length; ++i ) { counts[i] = 0; } var objs = gd.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex < counts.length ) ++counts[obj.styleIndex]; var subobjs = obj.getSubObjects(); for ( var j = 0; j < subobjs.length; ++j ) { var subobj = subobjs.item(j); if ( subobj.styleIndex < counts.length ) ++counts[subobj.styleIndex]; } } for ( var i = 0; i < styles.length; ++i ) { if ( counts[i] == 0 ) styles.item(i).remove(); }
3774.3
as always, I am amazed at how quick you are Michael!
Thanks a lot,
does this script kill the empty layer? (his name)
3774.5 In reply to 3774.4
Hi Pilou, yes it deletes any layers (styles) that have no objects assigned to them.
3774.6 In reply to 3774.5
Thx for precision
One more for http://moiscript.weebly.com/ :)
Show messages: All  1  2-6
