Strange results after boolean difference
All  1-6  7-10
3669.7 In reply to 3669.4
I see what you mean. The cutters are Cyan, and the surfaces they create are Cyan too, so when I hide the cutters, it hides the new surfaces. Drove me crackers. Thanks guys.
3669.8
This is a good example where that particular ini switch would be nice exposed in the UI, just a tick box would do, in the browser somewhere.
I often, when modeling for render output, want some styles to be inherited and some not, and closing MoI to change this in the ini every time can get annoying.
3669.9 In reply to 3669.8
Hi Danny, well usually things like this kind of graduate to have checkboxes in the UI if they get mentioned or asked about frequently enough.
This one has just not come up very often, at least so far...
The next step up from an .ini file only setting is to have it available to scripts so that you can set it on a keyboard shortcut, that would be an easy initial next step for this once v3 is underway.
3669.10 In reply to 3669.9
Available to scripts would be just fine Micheal.
Show messages: All  1-6  7-10
