inference lock?
All  1-8  9-11
3526.9 In reply to 3526.8
Hi rabbit, also in MoI v3 it should not be difficult for me to add in an option so you could set up a shortcut key for a direction lock by keystroke. That would probably be useful for doing something like this in the 3D view.
re: Copy / Paste - also what you may have run into there is that if you want to copy from MoI to Rhino you need to keep MoI running while you are doing the paste into Rhino.
It won't work if you do something like copy, then shut down MoI, then go to Rhino and try to paste it in.
That's to save some memory - MoI "advertises" that it can create a Rhino file on the clipboard if some other program wants to use it. Then if some other program does want to use it, MoI needs to be running so it can respond to the windows clipboard saying "ok now put the data into the clipboard in that format you had advertised".
3526.10 In reply to 3526.9
cheers Michael
Yeah - so far I always use a keyboard with my programs, so there is always one hand free to use it, and, as long as all the cad / 3D programs i use can have shortcut keys set to be the same, it is easy to flip back and forth between them ...so, yes, an option to lock to direction via a key would be great.
can i just say here, since it as good a place as any, that your work on rhino way back in the first wips before V1 was released, which is when i discovered it, really changed my life insofar as 3D / CAD work goes. Previous to rhino I had used a stack of stuff on the Amiga platform, and finally 3D Studio release 2, which I did manage to get some good work out of; but rhino was a total revelation - its interface was so clear, its navigation so intuitive, and the ease with which one could create things (accurately) was stunning.
It is still a great program, and I really appreciate now all the 2D, dimensioning etc in it, because I can stay in one program for almost everything I do.. As for MOI, i just think of it as a super plug-in to rhino - often if something won't work there, it will work in MOI, and if it doesn't work in MOI, then something needs changing. I love that the view commands / orbit etc are the same, and that the one can cut and paste between them...thanks so much for your work, back then, and now...
best
rabbit
3526.11 In reply to 3526.10
Thanks rabbit, I'm glad that Rhino was useful to you way back then and still now! :)
Those early days before Rhino v1 were pretty crazy for me.
Show messages: All  1-8  9-11
