Curve through points - can the points be locked?
All  1-2  3-7
3520.3 In reply to 3520.2
cool trick!
3520.4 In reply to 3520.1
Hi Mike,
This is just a possible workaround.
Draw a line, then copy that line midpoint to top of each triangle (I have used cones)
Draw control point spline as shown.
Select the 3 points/line on top to adjust (with V2 you can use the manipulator to scale/rotate)
Other control points can be added if needed.
The control points on each side of the point on top of the cone do not need to be eqa distant, just need to be in line and be rotated/scaled from the center/top of cone.
This method does add extra weight to the curve, which may not be wanted.
3520.5 In reply to 3520.1
Hi Mike, in the future I would like to have a deeper history function that would allow you to see the original "through points" that you had picked to create that curve and allow you to manipulate them.
But that kind of "through point" editing is not currently available in MoI - instead if you want to change the curve to go through some different points you would generally need to delete the curve, and then draw in a new "curve through points" passing through those updated points.
3520.6
Excellent, both the above techniques will work for me! Thanks very much.
3520.7
Nice Work Steve...
You are proposed a Bezier Curve
" Made in House "
al
Show messages: All  1-2  3-7
