Dish
All  1-2  3-5
3426.3
Sorry this is brief, and rushed - have to dash out...
Have a look at the attached file.
After tracing half your parabolic curve ( using the freeform line with control points, in 'top view' with the 'points' turned on), I extruded half the height.
Then traced again quarter the oval outline shape of the dish, mirrored it and did a boolean diff. then mirrored it again to get the full height.
Maybe someone's else has another way...
- Hamish
3426.4 In reply to 3426.2
That is exactly what i was trying to produce! Thanks. I'd missed the trimming steps. f
3426.5 In reply to 3426.4
Heres an easier version to try that will have a cleaner surface.
I selected your curves and used the edit frame widget to flatten out from both directions. Then I just extruded a solid and cut it with a boolean diff to create the surface.
The new cutting curves are heavy as I did a rebuild with a tight tolerance on the curves. But you could easily make very light curves for the operation.
Show messages: All  1-2  3-5
