Edit/Extend command
321.1
When I make a surface by using Construct/Planar command with a planar curve (e.g. rectangle) as an input, I'm not able to use this trimmed surface as a boundary object for creating the line extension (Edit/Extend). This is the same for any cap that is created by Construct/Planar command. Is it a bug?
Petr
321.2 In reply to 321.1
Hi Petr, this is a bug, thank you for reporting it! It is now fixed for the next beta.
In the meantime a workaround is to save and reload the file - it should work after you reload it.
