Maintain height - sweep param
All  1-6  7-9
314.7
Michael, Nice whoopie cushion !!!! :)
JTB, i think if you want the ability to control the scaling it would require a network surface command so you could use additional rail curves to define the profile...
314.8 In reply to 314.5
After the sweep
Select the original curve (not the rail)
Show points
Move points
With that you will obtain the height and scale that you want ;)
EDITED: 16 Jan 2007 by PILOU
314.9
You can also control the shape of the sweep by using more than one object as the profile...
Show messages: All  1-6  7-9
