Recommended free renderer - An old question, maybe a new answer?
 1-7  8-27  28-47  48-67  68-69
3136.8 In reply to 3136.1
Hi argo,
How much money do you wish to spend each year on software?
I ask this because,now and then i see people complaining about software being to expensive.
I am just curious(no offence).
@Michael: I am agree with you :)
(but for files now you can survive :)
For the rest hum hum you must some learning ;)
For my part from Moi the only way seems ( because Blender Format 3DS, OBJ, FBX seems don't work (Alpha 2.5 version I suppose) :(
Moi --> SKP --> free Google Sketchup Textured ---> KMZ (rename .kmz in .zip then Unzipp) = DAE !
then import DAE inside Blender :)
F12 = Render (If you have put the camera at the good place :)
But after I must learn Blender and it's some painful for me :D
(not yet found how open the render view on the same screen of Default views !
Nothing is instinctive !
EDITED: 1 Dec 2009 by PILOU
3136.10 In reply to 3136.9
For me, this has always been the problem with Blender. Underneath all that weirdness is a very powerful program. I know there is a lot of power there because I have seen all the wonderful things that talented people have done with it. Unfortunately life is too short and I just don't have the time to fight with it. I have picked up lots of useful MoI tips on the forum (thanks guys) but don't feel I actually needed to learn MoI to use it because almost everything was intuitively obvious.
The Blender devs are between a rock and a hard place really. I suspect much of the current user base won't like the changes. Seems to me that the only way they can move forward is to provide classic and custom GUI's.
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
3136.11 In reply to 3136.10
< Unfortunately life is too short
That is the main problem! ;)
3136.12 In reply to 3136.1
Hi argo I personally use Maxwell Render and Vray But since you like kerkythea Ill recommend you take a look at Thea render http://www.thearender.com/cms/.... (Kerkythea & Thea come from the same developer, Thea is a brand new render application with many significant differences and advantages compared to kerkythea....
Why one should consider Thea? It is first of all, a multiple render engine which makes easy and convenient rendering in both biased and unbiased modes. But even more, the studio, integration and the all-in-one logic is another reason, also the Pricing Policy is big plus... (hopefully Ill also be replacing Maxwell + Vray with Thea)
Pricing comparison.
# Standard License
Thea Render- Price 390 € (including 2 RenderNode Licenses.)
Maxwell Render- 995 €
# RenderNode Price
Thea Render - 95 € (for 2 slave licenses)
Maxwell Render - 390 € (for 1 slave licenses)
3136.14 In reply to 3136.13
I'm sorry I also read this part <<<Can anyone recommend an easy to use renderer (cheap!)?
3136.15 In reply to 3136.14
So the more easy is podium http://www.suplugins.com (only 2 cursors) and cheap (179$) or free in 500*500 without logo or watermark but it's a plugin of the free Google Sketchup ;)
No problem as Moi has the Skp native format :)
A little less easy is TwillightRender and super cheap (99 $) http://www.twilightrender.com/ or free in
* 800 x 600 pixel maximum resolution
* Rendered image watermarks
* Images only savable as JPG
* XML export is disabled
LightUp 149 $ http://www.light-up.co.uk/ Real time render after one computation of the scene
Interest of this 3 programs is that you control all objects inside Google Sketchup the more easy modeler!
http://sketchup.google.com/intl/en/
And you have the biggest free objects library at http://sketchup.google.com/3dwarehouse/
And you have an another solution and free ;)
A new world of simulations in real time: export on any supports, computers, Web, console etc...
http://unity3d.com/ (free as Indy name section)
Have happy rendering!
Here Podium in free version 500*500 with a Moi Object : you see the interface with the 2 cursors
Small is beautiful ;)
3136.16 In reply to 3136.15
Twilight & Podium are based on the Kerkythea engine, The people behind Twilight & Podium they've licensed the Kerkythea SDK...in other words you should be able to get the same results with Kerkythea for FREE, if you don't mind the GUI...also note that Kerkythea it may not develop much since the developer is putting his effort to the new engine (Thea Render).
3136.17 In reply to 3136.16
Yes simplicity of UI and presets are the difference ;)
3136.18
Also an interseting app. is 3D PaintBrush (99,- € online from Germany)
http://www.3dpaintbrush.com/
•Import models from SketchUp, Rhino, 3DS, Autocad, STEP, IGES & OBJ files
•Capture 3D models from any graphics application running on your computer
•Drag and Drop Materials, Lights, Backgrounds and Animations
•Import images and apply them as textures and backgrounds
•Manipulate material properties like Diffuse and Specular color, transparency and shininess in real time
•Visualize and position lights in the scene as well as modify light properties like colour and direction. Modifications are reflected in the Graphics Area in real time
•Animate camera, material and position of components to create key frame animations
•Use Ray Tracing for exporting photo-realistic images from your 3D scene
•Export to 3D PDF
•Export to EXE (Executable format)
•Export to popular image formats like BMP, JPG, PNG, TIFF & GIF
•Export to 3DS, XAML, OBJ & SVG
•Export animations to Shockwave Flash (*.SWF) and Microsoft AVI (*.AVI)
It`s a product of Geometric...
3136.19
Wow, you ask a question before going to bed and get lots of great answers - thank you!
@ Pilow, @Michael @et all - I have looked at Blender (like everybody!) before "finding" MOI. Its certainly a fantastically powerful program with a fast-UI for the experienced user. Huge learning-curve and I imagine requires practice to keep the key-strokes in organic memory. Still, as many of the free renderers use it to set materials etc, I have run through a few tutorials and could see it being useful if I followed a process-list for the odd rendering. My personal summary: so powerful, so non-intuitive! (please don't flame me).
- Kind of reminds me of WordPerfect Vs. Word 20 odd years ago.
@Paolo - No offence taken at all! Answer is "very little" $E ;-) .
This is purely a hobby for me with no financial gain (actually the opposite), and with 20 mouths to feed in a recession....
@neo - thanks I'll look at Thea, looks interesting. The developer/s working on Thea (with its potential for income), instead of working on KT would explain the tumble-weeds blowing thru the KT website. Perfectly understandable really.
@Ralf-S - another interesting program requiring investigation, thanks as well.
Looks like I need to spend some more "quality time" with the PC tonight!
Thank you all, any more?
Regards - Brendan (argo)
3136.20 In reply to 3136.19
Hi Brendan, so also same as 2 years ago one inexpensive commercial choice is Carrara - there is a stripped down version called Carrara 7 Express (http://www.daz3d.com/i/software/carrara?_m=d) which costs $90.
3136.21 In reply to 3136.19
Hi Brendan,
There's a free version of truespace 7.6 available, although I don't' know about the render quality or ease of use...
Good luck with your research.
Marc
3136.22
Some more options to investigate - thanks Guys.
3136.23
If cost is a concern and Blender does not suit might I suggest Bryce 5.5 .... It is an older 3D program that is of a different sort but it imports .obj files rather well. The interface is unusual and seemed to attract artists and repel CAD guys. DAZ still sells it as version 6.1 which includes HDRI support but v5.5 was a relatively fast & stable version.
You can get it here: http://www.daz3d.com/i/support/downloads?product=bryce&_m=d
The only caveat is that you must register for a free DAZ account to get the serial number...
BTW: I notice that the manual is still available as well as the v5.5c upgrade, I definitely recommend grabbing these if you plan to use the program.
To show you what you might expect of it I have included a MoI model and the resulting Bryce render.
Hope this helps,
David
Size: 210.5 KB, Downloaded: 107 times, Dimensions: 806x724px
Size: 346 KB, Downloaded: 75 times, Dimensions: 799x654px
3136.24 In reply to 3136.21
I can speak a little about the default renderer in truespace. It is known as Lightworks and for checking your model as you work it is nicely integrated into truespace. It isn't however, in my opinion, a patch on Kerkythea or some of the other free renderers out there. Like Blender, there is a lot of power buried in the truespace gui (which up to V6 I actually like, don't really get the V7 gui). Given that it is free I think it is well worth downloading.
For a while truespace was also a cheap path into vray. They don't offer cheap vray anymore as far as I know but I'm guessing the integration is still there?
Mark
3136.25
Thank you all.
I thought I would look at Podium first as it looks simple enough to use and 500x500 image size would certainly meet my immediate needs (which are to visualise a model before 3D printing). Thanks Pilou.
David, Bryce 5.5 also looks intriguing, the render you posted is exactly the sort of thing I am looking to "build". Cheers for that as well.
There are some great options out there it would seem! I hope this thread helps others that might also be looking for a solution to start out with.
Cheers - Brendan.
3136.26
I recommend you check out the tutorial that I made on how to import MOI models into Blender and then render with Lux render. It hopefully breaks down some of the "Blender is hard!" barriers and allows you see the power of a stunning render engine, Lux render.
You can find it here:
http://www.vimeo.com/4810249
Phil
PS, Michael, you are correct in that the Blender file dialog box is AWFUL! It's so cluttered. Hopefully it will continue to evolve and improve as 2.5 is only in Alpha 0 status.
EDITED: 2 Dec 2009 by PHILBO
3136.27
I seconed the motion on Bryce 5. I downloaded it a while back for free, not sure if it's still available at Daz for free, check it out.
I just posted some examples in gallery. See "recent additions" Old West Firearms.
Show messages:  1-7  8-27  28-47  48-67  68-69
