Oct 19 beta OBJ export problems
All  1-3  4-7
3007.4 In reply to 3007.1
Hi Al, I'm glad you got it figured out!
I took a quick look at your 2 files anyway, and it looks like the flashlight2.obj file has different style text line endings than MoI itself generates - was that run through some external processing step after it was saved from MoI?
> 2. Shouldn't you allow at least one beta overlap period to
> avoid a new bug leaving a user dead in the water.
Yeah normally I try to do this. In this particular release I was hoping to have it be the last one for v2 and so I pushed a bit longer than normal to try and get everything in there (which still didn't happen though).
3007.5 In reply to 3007.4
Michael,
Yes, I uploaded the wrong Flashlight2.obj file. That one was processed my code to delete all the "vt" lines.
The whole post was triggered by a single character typo in my own code. The problem just happened to surface just after I downloaded the new MoI beta, so of course I blamed it all on you!!!
Sorry,
Al
3007.6 In reply to 3007.5
Hi Al, no problem!
For the next beta, I've added in an option in the moi.ini file so you can disable writing out texture coordinates (the vt lines) from the OBJ file generated by MoI.
So that may help to eliminate your extra processing step, unless you were doing other things in that step as well.
But anyway, in the next beta it will be this setting:
[OBJ Export]
WriteTextureCoordinates=y
3007.7 In reply to 3007.6
Wow! Thanks Michael. That will definitely steamline things on my end.
Al
Show messages: All  1-3  4-7
