fillet error
All  1  2-3
264.2 In reply to 264.1
Hi Isaac - I was able to fillet this over here:
That was with a fillet radius of 0.8 . There isn't enough room there to build a fillet very much larger than that, are you possibly trying to use a radius of 1.0 or larger? If so then that is the problem.
Often times it is surprising how much space a fillet takes up, it is fairly easy for it not to fit. So sometimes when you are having problems you might try using a smaller and smaller radius to see if that gives any results.
There are actually a lot of other situations where fillets can fail as well though, especially in cases where there are many edges coming together at a corner.
264.3 In reply to 264.2
doh...!! yup...
i fogot to setup my units after the new install. and here i was trying to figure out why a fillet radius of 2 won't work..
..too much egg nog
cheers!
Show messages: All  1  2-3
