Batwings
 1-9  10-24
2511.10
Hi Torolf
Excused the ignorance ,but I have difficulty to construct to this detail surface,
you could show the steps to me for the construction of single patch and its
spatial positioning-
Tnx in advanced
al
2511.11 In reply to 2511.10
But drawing of the 2 internal curvated lines must be calculated because there will be possible overlaps during the Mirror and rotation!
2511.12
Frenchy thanks,
the construction of the patch with network I had happens it, what me it is not clear and in which
sequence and with which axis to rotate and to mirror the Surface ones -
But still I have in spite of everything not understood.
Evidently they are much hard one
Sorry
al
2511.13
hello all :)
I'm doing a video the day for everyone :)
ciao
torolf
2511.14 In reply to 2511.13
Very appetizing! :)
2511.15
hello all :)
my batwing video :)
http://www.jotero.com/bilder/moi/batwing/
ciao
torolf
2511.16 In reply to 2511.15
Cool video!
Your add the 2 crossing curves curvating on the surface : it's just for the design & easy view but are not necessary for the follow mirror rotate....?
PS you can make all zooms 4 views in one click by Right Click on the Reset Button (or two if some objects are selected) ;)
EDITED: 3 Apr 2009 by PILOU
2511.17
Many tanks Torolf
you are great.
al
2511.18
Help me.. the Batwings will not go away!!!
After every session, I check "Mark as Read" -Visible discussions- and all the threads become hidden.
Yet, without fail, the next time I log in, Batwings is back up at the top of the list!
And there's never anything new about them that should make them come back.
I have nothing against Batwings or the people who like them,
I just don't want to see them every time!
Is it me? Am I doing something wrong? :-)
Jesse
EDITED: 15 Dec 2009 by JESSE
2511.19 In reply to 2511.18
Hi Jesse. I have not found a "Mark as Read". THe way the forum works is if you read it, it is marked as read. In the drop-down of the more menu, there is a "Mark as UNREAD" option, perhaps you are checking this everytime and so it returns????
Try just reading it and logging out and log back in again. See if it is set as read.
2511.20 In reply to 2511.18
Hi Jesse, hmmm that is an odd one.
Sounds like it may be some kind of bug in the forum, I have not seen that before though.
You might try clearing cookies in your browser, and also try this link which clears out some other possibly cached forum stuff:
http://moi3d.com/forum/logon.php?webtag=MOI&deletecookie=yes
Also at the top of the topic list on the left side pane of the forum, there is a View: option, is that set to "View: All discussions" when that happens, or is it possibly set to something else.
The way it is supposed to work is that it should get marked as read after you just click on it one time, it shouldn't be necessary to do that "Mark as read" thing.
Let me know if it continues after clearing cookies, maybe there is something messed up in the database that is not letting the read status for you to get updated properly.
2511.21 In reply to 2511.20
Thanks! that link fixed it. I know it was trivial thing but it was driving me completely batty! :-)
Jesse
2511.22
hi hello to everyone..
i'm new in the minimal surfaces world.. i need to learn how to model several minimal surfaces but controling in some way the results, so i need to learn how to do it quantitaive..any advice? which math topics should i learn etc?
many thanks
idmoshenissan@gmail.com
2511.23 In reply to 2511.22
Hi mosh, you might check out surface evolver:
http://www.susqu.edu/facstaff/b/brakke/evolver/evolver.html
2511.24 In reply to 2511.22
There are parametric scripts for Enneper, Henneberg, Scherk1 and Scherk2.
Catenoid and Helicoid are easy.
EDITED: 11 Aug 2014 by BEMFARMER
Show messages:  1-9  10-24
