Problems when saving... MOI crashes
250.1
I can't understand what happened. A very simple model, just extruded rectangulars and some cylinders for diff. boolean operation.
Michael, can you please tell me if you can correct this file, it will save me some time.
EDITED: 27 Dec 2006 by JTB
250.2 In reply to 250.1
I was able to salvage some stuff, it's attached.
So the crash happened right in the middle of the save, leaving the file partially written?
250.3 In reply to 250.2
So there are at least 2 bugs here - one is that MoI could get stuck in an infinite loop when trying to read a mangled file, such as one that was partially written. I have fixed this one for the next beta.
The other one is harder to track down, some bug in one of the booleans generated an invalid mangled object, which then caused save to crash. This is more difficult to pinpoint, because the actual bug happened before the save.
If you happen to know which objects were most recently booleaned before things went wrong, that could be helpful in tracking this down.
Also, after a crash there should be a crash report file generated inside your MoI directory under \Program Files, these will be named moi_report1.zip, moi_report2.zip, etc.. if you can e-mail these to me at moi@moi3d.com that could be useful too.
