multiple sweep?
 1-15  16-22
2441.16
Yes thanks. Yes for me moi will only ever be used for modelling (possibly if there is an option of NPR rendering for quick stuff that would be useful) I would hate to see you get bogged down in too much rendering stuff. However if it is possible to have any small tools to help out with the UV mapping that would really be appreciated but i understand not as high as modelling tools in the priority list. One thing I would love is the ability to draw a spline that told moi the direction of the map - my current project has a gluelam frame (rough outline below) it would be fantastic if it was possible to just draw a spline (red line) that would create the appropriate uvs for stretching and distorting a map along that spline. That would be my only real request with regards mapping as the rest you can usually do with standard mapping projections.
Size: 40.1 KB, Downloaded: 12 times, Dimensions: 577x463px
2441.17 In reply to 2441.16
Hi Rob, how are you building that shape currently?
If you do it with a 2-rail sweep that should actually create UVs that follow that curve...
Basically the UVs from MoI come directly from the surface data, it is probably not going to be a very easy thing to set up ways to morph or mush them around, other than squishing around your surfaces themselves which will move the UVs with them when they are edited.
re: NPR I am pretty interested in doing some basic quick NPR type stuff, I'd like to generally incorporate some basic 2D illustration type stuff in as time goes on. It is hard to know when that will actually come about but hopefully I'll be able to get into it for v3.
2441.18
I thought you might suggest the two rail sweep and yeah i'll give it a go here thanks. But OK I understand it's probably a big task to add a UV toolset - hopefully one day it might materialise though! Cheers
2441.19
Ah tried the two rail sweep and all its assorted options and get some geometry errors and the object gets split up. any ideas for a work around?
2441.20 In reply to 2441.19
I was wondering if a cheat could be to create the "Sheet of points" then pull or stretch the points around then trim out the shape after.
Would this manipulate that UV structure?
Burr
2441.21 In reply to 2441.20
Hi burr,
Yup, the UVs will basically follow the surface and if you stretch the surface out by control point editing the UVs will also stretch in the same way.
2441.22 In reply to 2441.19
Hi Rob,
You might try placing some additional profiles to force a specific connection between the rails at a good spot.
If you'd like to post or e-mail the .3dm model file with those curves in it, I can try to make an example for you.
One problem with sweep can be when the profile curves go along the rails at sort of different rates of speed, if you place another profile in the middle of the sweep or at a strategic location where they are not connecting up well, then that will force an additional "synchornization spot" to happen in that location which can tone down that kind of a problem.
Also currently MoI's sweep has a problem where it is sensitive to the control point spacing of the curves, I'm going to be doing an overhaul of sweep before v2 is finished to make it more focused on pure distance traveled along the curves rather than being sensitive to control point spacing.
Show messages:  1-15  16-22
