chamfer on lines?
All  1-8  9-11
2402.9 In reply to 2402.8
Hi rhodesy,
> I don't suppose there is a way to override the moi acuracy
> for calculation to take this into effect?
There isn't currently any way to override the accuracy level, but I do have some plans to try and make the accuracy more adaptive to the size of the model rather than fixed at one specific size. There are a couple of things that do this in v2 so far such as Join and Network. As time goes on I want to tune up more things to work in a similar way but it can tend to be a somewhat delicate area to mess around with.
> Just tried converting the model into cm and it works a treat -
> much faster and the file is down to 29mb.
What will probably happen also is that your file size shouldn't grow quite as quickly when you do some additional operations at the somewhat smaller size level, like booleans, etc... since those will generate less dense intersection curves.
I'm actually kind of surprised that it made much of difference right away.
> I like the way moi automatically scales your whole scene for
> you - would be cool to be able to scale the background images
> at the same time.
Oops, that is definitely an omission there! Yeah that would definitely be better for those to scale along with objects. I should be able to fix it up to do that in the next v2 beta. By the way you can disable the scaling if you wish by going to Options / General / Unit options / Scale on unit system change checkbox.
EDITED: 15 Feb 2009 by MICHAEL GIBSON
2402.10
Great thanks for the explaination and the scaling of images addition. Im working in cm now and things are running smoother. Think I should probably try working in metres though as many of our buildings are over 3000cm long. Cheers
2402.11 In reply to 2402.10
Hi rhodesy, I was able to track down the chamfer problem to a bug in the geometry library, it was overly sensitive to some slight accuracy drift (like in the area of 0.000000000000001 units) that can occur when doing operations on curves that are a bit of a distance away from the origin.
I've fixed this up for the next v2 beta, so that chamfer will be able to work on your original curves there. But it is still a good idea to work in that new scale anyway to avoid that "dense intersection curve" problem currently.
I've also tuned up the unit system scaling to also apply to background images for the next v2 beta as well.
Thanks for reporting the problems and for posting the file so I could debug it over here!
Show messages: All  1-8  9-11
