problem filleting a planar surface
All  1-2  3-4
2388.3 In reply to 2388.1
Hi Jonzker - the regular filleter really does not like this shape very much, it seems to have a lot of problems with the area that is sloped out the most.
I was able to sort of deconstruct and re-construct the object by using surface/surface filleting and some manual surface trimming in that area that the regular edge-based filleter did not handle properly, I have attached the result here as question2.3dm .
This version should now be able to fillet that planar side, you can select the face there:
And then a fillet smaller than radius 1 (like 0.8 or something for example) should work on this version:
Looks like definitely something that needs to be tuned up in the filleter but I hope this tuned up version here will help you complete your current task at hand.
2388.4 In reply to 2388.3
wow thanks michael,, ye that edge you pointed might be the trouble, i think my previous fillet created that gap and for some reason it didnt fillet the edge properly, thanks a bunch sir
Show messages: All  1-2  3-4
