comment utiliser la fonction Fillet ?
All  1-4  5-10
2295.5 In reply to 2295.1
Hi alexito, also be aware that on some places of your model the edges are split into 2 edges, not just one edge, like here:
So in those spots make sure you are picking both the bottom and top edges to fillet, if you only pick just one half then the fillet will not work.
Then as others have mentioned there isn't enough space there to get too much larger than 0.5 or so.
Those edges got split into half during the boolean due to the placement of the "seam" edge of your sphere. Your sphere looks like this:
Notice how the seam of the sphere is running along the side area? That is a result from drawing the sphere in the Front view initially - if you draw it in the Top view the seam will be oriented vertically rather than horizontally and it will be a little bit more out of your way as far as interacting with the other pieces you are booleaning...
It can be a little more convenient to orient a sphere or cylinder so that its seam is somewhat more out of the way from the other objects you are going to combine with it.
2295.6 In reply to 2295.4
Salut Schbeurd !
Merci pour ta reponse.
En fait j'ai fait reussi avec la sphere orienté dans l'autre sens comme j'ai pu comprendre sur l'exemple de Michael Gibson.
En fait je suis en pleine prise en main je m'affole un peu mais ça va venir.
Je devrais peut-etre travailler sur les versions Beta ? Qu'est-ce que tu en pense ?
Bon en tout cas à bientot sur le forum en français..
Merci et bonannée a toi.
2295.7 In reply to 2295.5
Hi Michael !
It's works with the sphere oriented horizontally I have made a quick test not with the same object but it seems that it work like that.
Thank you.
I have just received the program and I just start to enjoy it.
Happy new year!
2295.8 In reply to 2295.6
Et oui les versions bétas ont plus de possibilités même s'il reste quelques petits bugs par-ci par-là ;)
Bonne découverte!
2295.9 In reply to 2295.8
Hey le Pilou est revenu de vacances o)
2295.10 In reply to 2295.9
Yessssssss :)
Show messages: All  1-4  5-10
