Deslection workflow
All  1-15  16-19
2218.16 In reply to 2218.15
Hi Pilou, yeah space bar or H are personal shortcuts that you have added in at some point.
The default shortcuts are pretty minimal:
F1 for help
Ctrl+A for select all
Ctrl+C for copy to clipboard
Ctrl+N for File/New
Ctrl+O for File/Open
Ctrl+S for File/Save
Ctrl+V for past from clipboard
Ctrl+X for cut to clipboard
Ctrl+Y redo
Ctrl+Z undo
Delete Delete
If you like to use shortcuts, then I generally assume that you'll want to add in personalized ones that suit what you want.
2218.17 In reply to 2218.16
Minimal but useful to know it even some are classical ;)
I will add that on the wiki (on the FAQ ? because sections of the help are closed for Edit)
EDITED: 6 Dec 2008 by PILOU
2218.18 In reply to 2218.17
Hi Pilou, probably not on the FAQ since that is for "Frequently" asked questions and this does not really come up frequently...
You could make a new keyboard shortcuts page if you think it is necessary.
2218.19 In reply to 2218.18
OK, I will make that :)
Show messages: All  1-15  16-19
