Smooth transition
 1-14  15-34  35-54  55-68
2140.55
Not as much fun as trying to build it yourself ... but for reference, check out
http://www.rhino3d.nl/pythposter/pyth3dm-eng.html
all .3dm files
cheers,
eric
2140.56 In reply to 2140.54
Thanks Steve.
These are the times when one wishes the simple constructions of polyhedron options in the Carrara Vertex Room could be saved to bring into MoI!
Brian
EDITED: 31 Dec 2008 by BWTR
2140.57 In reply to 2140.56
Eric
What a great site! All saved into my MoI file saves recources! Thanks.
Brian
2140.58 In reply to 2140.56
If you want to mess around with polyhedra, you can save off of Rinus Roelofs' model files from that link that Eric posted:
Then when you want to bring one into your current project use File / Import to load it into your current file.
EDIT: Looks like you figured that out already! :)
2140.59 In reply to 2140.53
Hi Burr,
> Is there a name for the intersection or method you created
> with the two circles for the Dodecahedron? I will be studying
> this a bit and would like to go a little deeper with some
> googleing/wikipedia stuff.
I'm not really aware of any special name for that method... I would call it a kind of "geometric" solution since it is setting up additional geometry to intersect to find the right point.
For more information you might try googling "platonic solids". You'll probably find some other methods that calculate what the various angles have to be for the pieces to meet exactly.
2140.60 In reply to 2140.59
Eric/Michael
For interest
Those polyhedron files do not Thumbnail--as do not MoI 3DM files!
Brian
2140.61 In reply to 2140.60
> For interest
They were possibly saved from Rhino using the "Save small" function which tries to reduce the amount of stuff stored in the file.
If you want to get Thumbnails, save them from Rhino without using Save small and that should make a thumbnail image inside the file.
2140.62 In reply to 2140.61
Michael
I only have the demo of Rhino.
The thought of having to take MoI files, via Rhino, to save them out with the thumbnail???
Something for the MoI wish list?
Brian
2140.63 In reply to 2140.62
Hi Brian, yup it is already on the wish list.
That's just a method you can use if getting the thumbnail is an important thing for you to have right now.
2140.64 In reply to 2140.60
I use Firefox as my web browser, with that I'm able to save the web page with all it's images.
So here's a ZIP file with all the relevant images for you, just keep them in the same folder with the 3DM files.
Hope it's of use to you.
regards Colin
2140.65 In reply to 2140.64
Thanks Colin
I am lucky to have very top Adobe Suite stuff (Acrobat8 Pro) so I do (and did) save web pages like that as a pdf file.
Brian
PS It's my sons spare computer that I use. Full CS3 Extended Suite.
And, I have never had problems, in all these past years ,with Windows IE! I love it!
EDITED: 9 Nov 2008 by BWTR
2140.66
Dunno if this solution has been proposed yet
EDITED: 18 Nov 2008 by LWAN
2140.67 In reply to 2140.66
That looks pretty close to PaQ's method here, another good one lwan, thanks for posting it.
2140.68 In reply to 2140.67
oops yes indeed, looks pretty close :)
Show messages:  1-14  15-34  35-54  55-68
