RhinoArt
1932.1
maybe a stupid question but could it be possible to use RhinArt together with MOI or is ther a similar product..
http://www.rhinocam.com/Products/RhinoArt.shtml
1932.2 In reply to 1932.1
Hi stoltoguzzi,
I don't think that RhinoArt will work with MoI - first of all it is a Rhino plug-in so you definitely need Rhino to run it, and then also it looks like it generates triangle mesh data.
MoI doesn't work with that kind of triangle mesh data - MoI is only currently focused on working on NURBS surface type data instead...
One thing you might want to check out is zsurf, which can generate a NURBS relief type surface from an image, it might be able to do what you need. Check out these posts for some more information:
http://moi3d.com/forum/index.php?webtag=MOI&msg=602.7
http://moi3d.com/forum/index.php?webtag=MOI&msg=863.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=636.1
1932.3 In reply to 1932.2
thanks for all this usefull links!!
Stolguzzi
