drag and drop request
All  1-10  11-17
1886.11 In reply to 1886.10
On the subject of 'move', I was just thinking could you probably incorporate it in the current object edit frame, referring to the picture you would select the move widget, which would activate the point selection, select the origin point (first mouse click) make it stick drag to destination then pick target point (second mouse click) to release.
1886.12 In reply to 1886.11
Hi Danny, it's an interesting idea!
But one factor is that I have tried to keep that edit frame about as light as it possibly can be, so that it will not clutter up the screen.
That has some pretty big benefits since it then enables it to be more easily turned on all the time.
So I'm kind of a bit hesitant to add a bunch more stuff into it, unless maybe it was pretty heavily used.
You can already move an object by just clicking and dragging directly on it, and that drag operation will snap on to any key points that were close to your mouse.
So for simple things (like snap an end of a line to another line's end), the existing drag function should be able to do that job already.
1886.13 In reply to 1886.12
Yeah, I use that all the time, it was just a thought when doing assembly stuff where you can say pick the center of a cylinder and line it up to the center of a hole that is slightly bigger, no big deal I use the 'move' function for this anyway, I also thought this because you mentioned you are going to have the part active after merge was executed in the drag and drop.
1886.14 In reply to 1886.13
Hi Danny - I guess the hope I would have there would be that you're doing assembly type operations at a somewhat less level of frequency.
If you're not doing something at a high level of frequency, then it isn't such a burden to fire up an auxiliary command like Move.
In fact, it is a problem to kind of "over optimize" and try to make a less frequently used thing very prominent in the regular UI because then it takes up some of the overall UI mojo for not a big gain.
The thing that will be good about the parts being selected on merge is that they will be all set up for you to do a Move (or whatever) operation on them right away without needing to select them first, so it will actually work smoothly with Move.
1886.15 In reply to 1886.4
Hi okapi,
I have set up drag & drop support for the next v2 beta.
After you drop a File or Files on the MoI window, There will be an options dialog displayed:
If you use "Open file" the current file will be closed and replaced by the new content.
If you use "Merge file", then any current data will stay in place and the dropped files will be added to it the same as the File/Import command.
If you have an empty scene then it will not prompt you and will do an Open.
If you want to open everything in separate MoI program instances, then do a right-click on the files in Windows Explorer and pick "Open" or "Open with", that should open them in that way.
1886.16 In reply to 1886.15
excellent michael !
I think it sounds best, the different options sound very logical
1886.17 In reply to 1886.15
...nice job Micheal - I will look forward to that!!
Rgds,
--Paul--
Show messages: All  1-10  11-17
