Simple Shell
All  1  2-8
1624.2 In reply to 1624.1
Hi Paul, well it's not really totally up to me - I get the shelling function from the geometry library that I license.
I have noticed that there are some particular bugs involving offsets of surfaces that have a "pole" point in them (where one surface edge is collapsed down to a single point) - that's the part that is going wrong in this case. So far most of the basic shelling problems I have seen seem to involve that particular bug. Hopefully if I can fix that one bug it should tune up basic shelling to work quite a bit better.
If you have shapes without those kinds of poles in them, you'll probably see basic shelling work pretty well.
I doubt that it will ever really get to the same level of sophistication as stuff like Pro/E or SolidWorks, but I'll probably be able to get basic stuff like your example here working better.
1624.3 In reply to 1624.2
Thanks for the reply.
Even just creating a rectangular extrusion with a 5mm radius on the corners, then trying to shell 6/7mm fails when
most other systems manage that ?
I for one would be very grateful for any improvements you can make.
TIA
--Paul
1624.4 In reply to 1624.3
Hi Paul - that new one you mention involves surfaces being totally consumed during the offset. That tends to be a pretty complex area, I would not consider any kind of self-intersection or surface consuming type scenarios to fit in the "simple shell" category, sorry.... I don't have a whole lot of optimism that such things will happen anytime soon.
If you need more robust shelling with stuff like consumed surfaces / interfering offsets, stuff like that, it is not likely that MoI is going to do those jobs for you. You'll need to use something Pro/E, SolidWorks, etc... for that kind of stuff. That's not going to change anytime soon.
But I do think that it will be possible to get non-interfering and non-consuming situations to work better though.
1624.5 In reply to 1624.4
Cheers Michael,
I didnt mean it was simple for this to get done or calculate.....it's just our other modeler goes a lot lot further than this.
Well, that would be great if you can tune it up some more - thanks!!
Would you happen to know what Cad product deals with shelling Surfs/Solids the best ?
EDITED: 23 May 2008 by KARTER
1624.6 In reply to 1624.5
Hi Paul,
I don't really know for sure, but my guess would be either Pro/E or SolidWorks.
1624.7
That's right Michael, I think any modeling package that uses the parasolid kernel is strong in this area, If you do a lot of shelling that's fine, if not, there is always a workaround in MoI to get the same result.
1624.8 In reply to 1624.7
Thanks Michael / DannyT - Some of our mould cavities and quite complex and shelling can be a big problem sometimes....and
would be almost impossible to workaround in MoI (at the moment at might add)
I will do more investigation...in the meantime im going to buy MoI now :-)
Cheers,
--Paul
Show messages: All  1  2-8
