[Q] Turn on points for polysurfaces
All  1-3  4-7
1250.4
Hi Momso. In Rhino 4, you can use the SurfaceCreasing plugin to create single surface versions of all those primitives in your screenshot. The surface creasing works on all surface creation tools (extrude, loft, sweep, etc). And you can turn on the control points for a creased surface... The difference is that in Moi, a box is represented by 6 sides. In Rhino, a creased surface box is just one surface, which has a toplogy similar to that of a sphere (see my attached image)...
jonah
1250.5 In reply to 1250.4
Hi jonah,
Thanks a lot for the info. I have found the plugin from the RhinoLab. I tried the plugin with Rhino4SR2.
For example, draw a square curve then CreasseSplitting (with SplitAlongCreases=No), then ExtrudeCrv with the curve. but, it's a polysurface, not a single surface.
When extruding the curve, 'Cap=No' is making single surface, but 'Cap=Yes' is making polysurface and cannot turn on points. My objects are different from your image. What is my mistake?
Sorry all for the question about Rhino in the MoI Forum.
/momso
1250.6 In reply to 1250.5
Hi Momso. i replied to your question in the Rhino NG...
jonah
1250.7 In reply to 1250.6
Hi jonah - Thanks a lot. I'll see it.
/momso
Show messages: All  1-3  4-7
