Fillet - Need Help
All  1-6  7-14
1225.7 In reply to 1225.6
Hi Ed, did you have the problem source curves in that .3dm model file you attached above? If not, then can you please post them too, or send them to me at moi@moi3d.com?
I would like to check them out when I return next week and try to figure out what was causing the problem, maybe it is something I can fix up to work better.
1225.8 In reply to 1225.7
Michael - I wrote over the old file.
If I have an issue in the future I'll send the EPS export from Corel.
The original Corel drawing had several edits to the control points on the curved portion of the cutout. On the new version I just made a circle and a rectangle and subtracted to get the cut-out shape in Corel. Then saved as eps.
Ed
1225.9 In reply to 1225.8
Hi Ed, well no big deal just in the future if you run into something similar it is a big help if you can send the problem file to me, that way I can see if I can fix things up to stop it from happening. Sometimes it is pretty hard to figure out what might have gone wrong without the actual example file in hand.
Your rendering in HyperShot is looking good! It seems like MoI and HyperShot make a pretty nice combination with one another.
For HyperShot rendering, you may find this OBJ editor utility useful from here: http://moi3d.com/resources#SeparateOBJ_editor - that program can be used to tweak an .obj file written by MoI to make it easier to assign different materials to different sub portions of an object in HyperShot.
1225.10 In reply to 1225.9
We'll do.
Yep - been using your separateOBJ program for assigning materials to my jewelry models when using HyperShot. Maybe that will become a "save-as" option?
The render above was saved directly out of the HyperShot "realtime" window. Took under 30 seconds for the render to complete after I stopped moving the object and the environmental HDR.
MoI + HyperShot under $400. Great, affordable combination. Both programs are new, so I expect even greater things to come in future revisions!
Note for potential users: HyperShot requires at least a dual core or multi-processor machine.
Ed
Marysville, Washington
EDITED: 2 Jan 2008 by ED
1225.11 In reply to 1225.10
Hi Ed,
The Hypershot render looks really nice. I downloaded the demo of Hypershot but haven't installed it yet. Is the dual core cpu an absolute must? I don't mind waiting on renders :) The only thing that seems a bit limiting with Hypershot is the small render size on the $200 version.
Mark
You have also a very easy renderer as plugin inside the free Google Sketchup !
Podium :) http://www.suplugins.com/
Here the object test of Steph without any regulate ! :) (30 seconds too)
Moi --> export format 3ds-->GoogleSketchup + Podium (free in 500*500 pixels images)
EDITED: 2 Jan 2008 by PILOU
1225.13 In reply to 1225.10
Hi Ed, it would be really cool to see more jewelry stuff that you do with MoI + HyperShot in the future, please post them if you get a chance!
Yup, for v2 it should get included more directly.
The speed is definitely one of the cooler parts for it. Also just general ease of use since you can get nice looking lighting with the HDR maps without any fuss.
1225.14 In reply to 1225.11
Hi Mark, it seemed to work ok for me on a single core, but slower of course.
Show messages: All  1-6  7-14
