New Dec-28 beta now available
 1-6  7-26  27-30
1217.27 In reply to 1217.26
Hi Petr,
Oops - it is supposed to work like you have it there, but there is a bug messing it up. I have fixed it for the next (and probably final) patch which I am going to try and gather together tomorrow.
I also have things fixed up so that selection is restored if you do a cancel or undo. So for example if you select some edges and then run Fillet, and then cancel, the original edges will be selected again.
1217.28 In reply to 1217.17
Hi Petr, re: window deselection - It is a little more complex than I want to deal with right now setting up a fully scriptable method (since you have to do stuff like wait for an initial click, etc..). But I have added the ability to use the Ctrl key to do deselection.
This will work with either a "normal" window started by clicking in open space, or with the shift+ctrl forced method that I mentioned earlier - after starting the forced window, release shift and keep ctrl down to make it do deselection instead.
The scriptable method will have to wait until v2 when I get a chance to jazz up more scripting stuff.
1217.29 In reply to 1217.25
> I also wish to have a separate undo/redo stack for "viewport changes"
This would be a great feature indeed.
Marc
1217.30 In reply to 1217.28
Hi Michael, The deselection using the Ctrl key is really good choice... I think the scriptable method to do deselection is no longer necessary! -Petr
Show messages:  1-6  7-26  27-30
