New Nov-18 beta available now
 1-5  6-25  26-29
1137.6 In reply to 1137.5
seems you have not refresh your Navigator or make a mistake with your files (erase, or relaunch the old one... ;)
1137.7 In reply to 1137.6
I go back to the download page, then click the reload button on my browser. Then I can see the Nov 18.
Thank`s for the tips. Now I am ready to reinstall MoI.
Regards,
Lish
1137.8 In reply to 1137.1
hi
I have a problem with a simple sweep
1137.9 In reply to 1137.8
I got the same problem. Normally the sharp edge should be without a break.
When I add radius to the rail, there is no break area. So the problem is ?
Regards,
Lish
1137.10
great to hear that the release is close :-)
I found "ShareIt" extremely good for selling my shader-plugins for messiah:studio. They do a perfect job with international sales, tax calculations etc., have a wide variety of payment options for a very reasonable fee and are dead solid so far and very helpful if I needed support. The developer interface is well thought out and has a lot of options for integration etc.
I can really recommend them.
As far as licensing goes: I hope you settle for something that doesn't hurt the paying customer more than the pirates. ;-)
I've encountered all types over the years from dongles to just a serial to node locked to just one machine. I still prefer dongles (although it can be a pain - I am up to 7 dongles already ;-) ) since I can put them on whatever machine I have to work with. If you decide to go for node-locking, I hope you will make it possible to install on at least two machines, so if something goes wrong on a deadline, one is still able to work with the second installation of MoI without having to contact you.
I also work sometimes on my main machine at the office - other times on location with the laptop and am thankful if that is not a problem.
I really look forward to what you come up with! :-)
Cheers and all the best for the final spurt to 1.0
Thomas
1137.11 In reply to 1137.8
Hi Nimi,
that problem is due to current limitation of sweeping along one rail which has a corner....
but if you copy a rail into some corner of rectangle and sweep a rectangle along that new rail and original one,
it should match your needs.
Petr
1137.12 In reply to 1137.11
Hi Petr...
I have tried your tips, but not work for me.
Sorry, are you sure did that inside MoI ( not rhino )
Regards,
Lish
1137.13 In reply to 1137.12
@lish : you have not good seen the Tyglik's example ;)
Your second rail is not at the good place ;)
Try another combinaison!
EDITED: 19 Nov 2007 by PILOU
1137.14 In reply to 1137.12
Hi Lish, what I meant when I said "some corner" was, if you copy the rail into the appropriate corner, then it should work :)
Just move the one of the rail curve into the opposite corner, so they will be in the same height at the Top viewport. -Petr
1137.15 In reply to 1137.14
@ Pilou & Petr..
I see now.
I just can do that in SWX
Thank`s
Regards,
Lish
1137.16 In reply to 1137.15
Yep, "me too" in Rhino... I guess Michael is going to tune it up for V2.
1137.17 In reply to 1137.8
Hi Nimi - for version 1.0 MoI does not handle mitering on a rail that has sharp corners in it.
Instead right now it will just sweep each segment of the rail as if it was an individual line segment, that's what gives the result that you are seeing.
But actually for the shape you are creating in this case, I would recommend drawing a vertical profile and then using extrude to punch it out to the side like this:
I am definitely planning on adding in corner mitering for sweep in version 2.0 though, I just didn't have time to get to it for version 1.0 .
1137.18 In reply to 1137.10
Hi Thomas, I've heard some good things about ShareIt - at the moment I'm planning on using Plimus which is very similar.
Re: licensing - node-locking / dongles
I still haven't exactly figured this out yet, but I really don't want to do a dongle since I'd rather avoid needing to actually ship physical stuff around...
If I do end up with some kind of node-locking, I do want to set it up to work on at least 2 machines. I don't want to have to make people contact me all the time either! That's why I may not go with node locking, to just reduce complexity and potential additional required support. But I need to dig into it for a bit to really evaluate pros and cons.
Thank you for your feedback and encouragement!
1137.19 In reply to 1137.1
Thanks again Michael G. I look forward to testing it. Looking forward to V1.0 as well :-)
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
1137.20
>>> Also now if you push F1 or click the help button while you are running a command, the reference section will open to the entry for that command.
Hmmm, If I understand correctly, you mean that if I'm pressing F1 while running the Extrude command (for example) the help file must open at the place where Extrude is explained. It always opens at the table of content here.
And one question... If I look for help on one feature, it will open an Internet Explorer window. Then, if I'm clicking "Help" for another feature a bit later, it will open another window. Is it how you want it to be ? Personally, I would prefer that only one window remains open and that the content updates if I look for help on another feature.
1137.21 In reply to 1137.20
Good point but personally, I would prefer a pop up window with in the app.
1137.22 In reply to 1137.20
< Hmmm, If I understand correctly, you mean that if I'm pressing F1 while running the Extrude command (for example) the help file must open at the place where Extrude is explained. It always opens at the table of content here.
I believe yes until you have not draw something it's the Command help, after drawing somthing the General help ;)
1137.23
To be more precise...
When no command is selected, MoI opens the moi_help.htm file.
When a command runs, MoI opens the moi_command_reference.htm file but not at the entry for that specific command.
1137.24 In reply to 1137.23
< When a command runs, MoI opens the moi_command_reference.htm file but not at the entry for a specific command
more precise :)
if you clic on the circle function then F1 you arrive on the circle help
if you clic on the circle function then draw a circle and then F1 you arrive on the moi_command_reference.htm
1137.25 In reply to 1137.24
Not here... ;-)) This is why I reported a possible problem (Internet Explorer 7)
Show messages:  1-5  6-25  26-29
