New Nov-18 beta available now
 1-2  3-22  23-29
1137.23
To be more precise...
When no command is selected, MoI opens the moi_help.htm file.
When a command runs, MoI opens the moi_command_reference.htm file but not at the entry for that specific command.
1137.24 In reply to 1137.23
< When a command runs, MoI opens the moi_command_reference.htm file but not at the entry for a specific command
more precise :)
if you clic on the circle function then F1 you arrive on the circle help
if you clic on the circle function then draw a circle and then F1 you arrive on the moi_command_reference.htm
1137.25 In reply to 1137.24
Not here... ;-)) This is why I reported a possible problem (Internet Explorer 7)
1137.26 In reply to 1137.20
Hi Bernard,
> Hmmm, If I understand correctly, you mean that if I'm pressing F1 while
> running the Extrude command (for example) the help file must open at the
> place where Extrude is explained. It always opens at the table of content here.
It seems that it doesn't work on IE7 - on IE6 or Firefox it works fine. I think it might be an IE7 bug, I'll see if I can do anything to work around it.
> Then, if I'm clicking "Help" for another feature a bit later, it will open another
> window. Is it how you want it to be ?
Not really - but it is kind of a side effect of using just plain HTML in a browser neutral way. I could get it to re-use the same window if I only opened up Internet Explorer to display the file, then I could talk to IE using some of its specific interfaces. But that might be kind of surprising to people who have set up Firefox or something else as their browser instead of IE...
1137.27 In reply to 1137.26
Michael,
OK, thanks. I hope you'll find some kind of workaround. Not really a problem for me.
Do you still plan to have a printable (PDF) version of the help file ? One I can study while I'm in the train... ;-))
1137.28 In reply to 1137.27
Hi Bernard, yeah what happens is I tell the web browser to open a page like this: file:///.../moi_command_reference.htm#extrude , and IE7 cruelly decides to throw out the #extrude part that is supposed to tell it which internal part to jump to.
I think I can figure out if the browser is IE7 and then use some of its more specialized interfaces to make it go to the right spot.
Yup! Pretty much I'm just going to glue it all together into one file and print it using one of those PDF printers to make the PDF version.
1137.29
thanks Michael!!!!
Show messages:  1-2  3-22  23-29
