Chamfer problem
All  1  2-6
1119.2 In reply to 1119.1
Chamfer works like this (from the drawing of your 2 lines) Normaly the 2 lines are joined at one angle before a chamfer ;)
So in your case (with lines no joined) select first Horizontal line then Vertical line
If you want only the jonction with your 2 lines (and don't know the measures) use Blend / Tangent(G1) with Bulge = 0
and will obtain also the green line :)
EDITED: 14 Nov 2007 by PILOU
1119.3 In reply to 1119.1
Hi Marco,
You can do that use extend command.
Please open attached video.
Regards,
Lish
1119.4
1119.5 In reply to 1119.1
Hi Marco, at some point I should be able to tune that up to work as you expected.
But when I originally looked at it from a kind of fresh view (instead of just an AutoCAD compatible view), I thought it was kind of strange to use fillet or chamfer for this purpose of extending objects without placing any fillet or chamfer on them.
So that's why I placed that functionality on Extend instead.
1119.6
Michael
You are a genius
Show messages: All  1  2-6
