Suggestion for improving the mesher.
All  1-2  3-5
1024.3 In reply to 1024.2
Well, it definitely doesn't look as good as when I let Zbrush divide it. Dropped tris, really skinny tris.
I'll email you a file.
1024.4 In reply to 1024.3
Hi Crusoe, the dropped tris may be a bug, I'll check into that tomorrow.
Zbrush is adding a center point interior to the n-gon when it triangulates it - MoI does not add any interior points and just triangulates using points on the boundary. That seems to be the difference that you are talking about.
I think I can add that, I'll take a look. It doesn't completely guarantee removing skinny triangles, but it does stop them from traversing the entire n-gon and I think it is an improvement.
However, in your example you have diced everything into small bits using "Divide larger than" so that each n-gon is convex, this type of situation does make it easier to add just a center point for the triangulation. It is not easy though for larger more complex n-gons that are non-convex. I would be interested to see what ZBrush does with those types of n-gons, like if you leave "Divide larger than" off.
1024.5 In reply to 1024.4
The new patch available here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1013.24
now performs this type of "connect to centroid point" triangulation when possible, it does seem to generate triangles that are a better proportioned.
Also I fixed a couple of bugs related to triangle optimization, that also should make a difference as well.
Show messages: All  1-2  3-5
