Node Wish List
 1-15  …  56-75  76-95  96-115  116-135  136-155  …  416-425
9581.96 In reply to 9581.95
It is always the same thing from the beginning : a node system created by Max Smirnov!
Better to load here http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
for have the the last extensions : supported by James
9581.97
Thanks! Is there somewhere any step by step tutorial about using the nodes?
9581.98 In reply to 9581.97
You have my Repository French / English for example of all native nodes
and quasi all extensions nodes :)
I will make rest the next year!
http://moiscript.weebly.com/biblio-elephant.html
Happy Christmas
and don't miss this true gem following (6.5 $ for the end's year) a pefect gift for children or other people! :)
You will can import inside your MOi Objects saved as OBJ format!!!
EDITED: 20 Dec 2019 by PILOU
9581.99
Ok Pilou will look at your repository. And... merry Christmas to you too! Merry Christmas to all people here! : - )
9581.100
Updated ImgSampler node.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Now able to have more than one ImgSampler nodes on a form. Added point array to output.
Wayne
9581.101 In reply to 9581.100
A-W-E-S-O-M-E !!!
9581.102 In reply to 9581.101
Happy New Year Everyone,
Here's another proposal for a new node:
Noise Generator Node
There are lots of applications for a 2D Perlin Noise fields for natural forms;
for example ocean wave simulation : http://www.alexlorman.com/oceanwavesimulation
Also it would be useful for random transformation the transition smoothly.
Of course 2D Noise fields could be imported as images into ImgSampler, however if they could be generated in NE
there would allow greater control and possibility of animation
Here is interest blog post on Perlin Noise in JavaScript
http://asserttrue.blogspot.com/2011/12/perlin-noise-in-javascript_31.html
An online 2D peril noise generator
http://www.kitfox.com/projects/perlinNoiseMaker/index.html
EDITED: 1 Jan 2020 by JFH
Message 9581.103 deleted 1 Jan 2020 by WAYNEHILL5202
9581.104 In reply to 9581.102
I believe that this new year about Elephant will be some laborious for me! :)
Happy new year!
PS some ideas of nodes! (look this free prog: JsPlacement) https://windmillart.net/?p=jsplacement
EDITED: 3 Jan 2020 by PILOU
9581.105
New Perlin Noise Node release
This node uses Ken Perlin's routine for generating PerlinNoise(c) data points.
Copy the PerlinNoise.js and perlinnoisefn.js function to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
I would like to thanks James for helping out with testing.
Wayne
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.102
Updated node. Jan 9 2020
EDITED: 17 Jan 2021 by WAYNEHILL5202
9581.106
Hi All,
Just putting up a NODE wish using the new image sampler would it be possible to create a node that can generate this sort of image based on input lines like supplied. Using MAX's FATLINES to create variable width lines based on those 2 variables linework overlaid by image.
Thanks Alex
EDITED: 23 Dec 2023 by ALEXPOLO
9581.107 In reply to 9581.106
FatLines Node
The proposed node would be analogous to Max's Fatlines script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
EDITED: 10 Jan 2020 by JFH
9581.108
Since there is an elevated interest in voronoi3d at the moment,
http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.177
I thought it would be worth adding it to the wishlist.
Voronoi3d Node
EDITED: 23 Jan 2020 by JFH
Message 9581.109 deleted 21 Mar 2020 by JFH
9581.110
EDITED: 19 Jan 2020 by WAYNEHILL5202
9581.111
Max Smirnov's Voronoi for the Node Editor
Based on his Voronoi script located at:
http://moi.maxsm.net/files/scripts/
Moi discussion reference:
Save voronoi.js file to this directory:
Wayne
9581.112 In reply to 9581.111
Excellent and all ready made for the Repository! Bravo!
Hyper cool!
EDITED: 19 Jan 2020 by PILOU
Does the ImageSampler has limitations ?
Format JPG, PNG ...?
Colors, Grey Levels, B&W, ...?
Size x,y ?
Does it possible to put a Version's Number of Extension, or a date...?
Because it's a mess for know what is the last one! :)
in the title for example (Titre = Title Fr / Eng ;)
I don't see PerlinNoise, PerlinNoiseFn ...
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.105
...in the Updated NodeEditor ?
EDITED: 23 Jan 2020 by PILOU
9581.114
RoundCrns Node
This is quite self-explanatory: the proposed node would apply rounding to corners of closed polylines/n-gons. (if it also worked on open polylines, that would be a bonus) This is different to "DelCorners" script as these corners would have a user determined radius.
I often use 2 x Construct2/offset nodes in sequence to achieve this result by offsetting inwards then offsetting outwards with "rounded" mode. Although this is mostly a workable solution it fails with small shapes and is not multiprocessing.
A great weekend to all
EDITED: 26 Jan 2020 by JFH
9581.115 In reply to 9581.113
The ImgSampler is limited by the processing time and memory it takes to make really large images.
It works with JPG, BMP, PNG, GIF and possibly other formats not tested.
All image colors are converted to grayscale during the processing. Size capacity was not tested. It is capable of very large renderings and will take time and memory to process them.
The latest version has the Crvs output and the image size below. Version numbering would be a good idea because of all the update improvements and more in the future.
PerlinNoiseFn is the function library for PerlinNoise. It does not show in the menu.
Wayne
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  416-425
