Node Wish List
 1-20  21-40  41-60  61-80  81-100  101-120  …  421-425
9581.61
Great NODE guys, please excuse my ignorance but how do you load the image into the node?
Also for some added inspiration on this tangent have a look at
https://www.lostminds.com/vectoraster7/
https://www.lostminds.com/patternodes2/
9581.62 In reply to 9581.60
Hi Wayne
If i test your node i haven't the same result
look at my screenshot
EDITED: 9 May 2020 by FINEMA
9581.63 In reply to 9581.61
HI AlexPolo,
Just mouse click inside the picture frame to load an image. Set the resolution of the image before loading the image. It is the first released version. Improvements will made from user feed back.
I will check out the referances.
Wayne
9581.64 In reply to 9581.62
Hi Finema,
Set the resolution of the knob, then reload the image. I will be making improvements on the interface.
Thank you,
Wayne
9581.65 In reply to 9581.64
thanks Wayne, it's perfect !
good job !
Hi all,
I have red squares for reRange and PointExt :-( so I can't test it, unfortunately.
Where do I find those two and where do I have to install those?
I had this problem in the past too, with another node.
Is there an up to date alphabetic list of all required things for node editor,
where one can find all in one place, i.e. like a complete GitHub repository?
EDITED: 13 Dec 2019 by STEFAN
9581.67 In reply to 9581.66
Normally last version of Node Editor is here managed by James
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
Thank you Pilou, that did the trick! :-)
9581.69
Hi Wayne,
I have red square highlight on image sampler node and cant load image file. I have updated node editor to current version and placed node in correct location in USER/APPDATA/ROAMING location.
Something else missing?
9581.70 In reply to 9581.69
Alex
Sorry, I had not yet updated CURRENT NODEEDITOR FOLDER to include ImgSampler.
Please reload with updated zip file attached to this post:
Have a great weekend
EDITED: 13 Dec 2019 by JFH
9581.71 In reply to 9581.70
James,
Can you holdup on including the new node into the zip file. There are some graphic updates that are being worked on.
Thank you,
Wayne
9581.72 In reply to 9581.70
Thanks all working now.
looking good.
Message 9581.73 deleted 13 Dec 2019 by JFH
Message 9581.74 deleted 13 Dec 2019 by JFH
9581.75
9581.76 In reply to 9581.75
CURRENT NODEEDITOR FOLDER updated with most recent version of ImgSampler:
9581.77 In reply to 9581.76
Cool and endless add to the my repository (no yet made...maybe this evening) :)
Hi Wayne and all,
thanks so much for your node, it is really cool!
Here is a small project I am currently working on:
The Go Gopher* Mascot from Google's programming language Go.
And the Image was taking from the Google folder on GitHub and
then redrawn with MoI, brought into the free ArtForm 4 to create
a relief and depth map from it. The depth map then was taken into
your node. Finally trimmed and scaled in MoI.
*Creator of the Go Gopher is Artist Renée French.
This is currently my progress:
gopher-NURBS
And final model, hope you like.
Go-Gopher-final8
Flatty personnage! :)
Show messages:  1-20  21-40  41-60  61-80  81-100  101-120  121-140  …  421-425
