Node Wish List
 1-20  …  381-400  401-420  421-425
9581.421 In reply to 9581.420
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
Size: 56.9 KB, Downloaded: 60 times, Dimensions: 832x312px
9581.422 In reply to 9581.421
Hi Mo,
Looks good.
Barry
9581.423
I have a pointarray of 3x by 6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
9581.424 In reply to 9581.423
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
9581.425 In reply to 9581.424
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
Show messages:  1-20  …  361-380  381-400  401-420  421-425
