Node Wish List
 1-17  …  378-397  398-417  418-425
9581.418 In reply to 9581.417
HI Psygorn, the one that Brian posted above is the one you need, the attachment ArrayGem_node.txt here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.415
So delete your ArrayGem.js that is giving the "invalid character #" message, download ArrayGem_node.txt from Brian's post above and rename it ArrayGem.js and put it into the node editor extensions folder.
9581.419 In reply to 9581.418
Thank you Michael.
-Psygorn
9581.420
Just a question.
I have been playing with r2d3 text node it as a input for text
but I can’t find away of using the input other than with numbers
or directly inputting text within the node.
Could a node that carries text be created that could be plugged into the
Text node ?
Cheers Barry
9581.421 In reply to 9581.420
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
Size: 56.9 KB, Downloaded: 60 times, Dimensions: 832x312px
9581.422 In reply to 9581.421
Hi Mo,
Looks good.
Barry
9581.423
I have a pointarray of 3x by 6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
9581.424 In reply to 9581.423
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
9581.425 In reply to 9581.424
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
Show messages:  1-17  …  358-377  378-397  398-417  418-425
