Node Wish List
 1-7  …  368-387  388-407  408-425
9581.408 In reply to 9581.406
After seeing your nod file, I came up with an idea to switch the text with an index number.
For "switch text by index" to work, you need to change the newly added "mode" property to "Index" and separate your text by three stars (***).
See the attached nod file.
EDITED: 2 Feb 2024 by MO_TE
9581.409 In reply to 9581.408
Hi Mo,
excellent node.
Is it possible to have a index position that shows the choices because they are not visible one run is pressed.
Many thanks
Barry
9581.410 In reply to 9581.409
Hi Barry
Sorry, It needs nodeeditor to be running to work properly.
Although, I added the page system to display the number of choices.
Updated my earlier post.
9581.411 In reply to 9581.387
Hi all,
I am using Google Chrome and when I want to download "ChamferCurve.js" it says "Virus Detected" and stops downloading process.
Do you know how I can fix this? or could you send it to me (like changing it's format from .js to .txt)
Edit: it also happens for "ArrayGem.js" so, if you could send that to me; I would appreciate it :-)
- Psygorn
EDITED: 9 Mar 2024 by DRILLBIT
9581.412 In reply to 9581.411
ArrayGem.txt
ChamferCurve.txt
EDITED: 18 Aug 2024 by ZOOEN
9581.413 In reply to 9581.412
Thank you Zooen,
But now I see this!
How can I fix this?
-Psygorn
9581.414 In reply to 9581.413
Hi Psygorn, re: "invalid character #" error, it looks like there are probably 2 different files named ArrayGem.js, one is the built in command in the commands folder and the other is I guess a node editor extension.
It looks like you've got the command one there instead of the node editor extension file like you want.
I'm not seeing where ArrayGem.js for the node editor is posted, can you post a link to the message where Chrome is not allowing you to download from?
9581.415 In reply to 9581.413
ArrayGem node:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1858
Rename .txt to ArrayGem.js.
Add to the extensions folder of nodeeditor. (AppData>etc.)
This node will be in the Objects2 node menu.
9581.416 In reply to 9581.414
Edit: how can I fix the issue of "invalid character #" error?
-Psygorn
EDITED: 10 Mar 2024 by DRILLBIT
9581.417 In reply to 9581.415
I got confused and need help here:
ArrayGem_node.js is a different file from ArrayGem.js.
and MOI shows an error message I showed in my previous reply.
- Psygorn
9581.418 In reply to 9581.417
HI Psygorn, the one that Brian posted above is the one you need, the attachment ArrayGem_node.txt here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.415
So delete your ArrayGem.js that is giving the "invalid character #" message, download ArrayGem_node.txt from Brian's post above and rename it ArrayGem.js and put it into the node editor extensions folder.
9581.419 In reply to 9581.418
Thank you Michael.
-Psygorn
9581.420
Just a question.
I have been playing with r2d3 text node it as a input for text
but I can’t find away of using the input other than with numbers
or directly inputting text within the node.
Could a node that carries text be created that could be plugged into the
Text node ?
Cheers Barry
9581.421 In reply to 9581.420
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
Size: 56.9 KB, Downloaded: 60 times, Dimensions: 832x312px
9581.422 In reply to 9581.421
Hi Mo,
Looks good.
Barry
9581.423
I have a pointarray of 3x by 6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
9581.424 In reply to 9581.423
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
9581.425 In reply to 9581.424
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
Show messages:  1-7  …  348-367  368-387  388-407  408-425
