Node Wish List
 1-16  …  337-356  357-376  377-396  397-416  417-425
9581.377 In reply to 9581.376
So, I found my mistake on fillet factory.
I thought the corners list's length should be equal to length of points generated by "generateVertices()" method.
But, It seems it should be equal to segments count.
That's why fillet node generates that curly effect in Barry's screenshots. It tries to fillet all corner points including the "G1" corner points
I just filtered the real "G0" points out of all corner points (segments start points).
script:
var inputs = moi.geometryDatabase.getSelectedObjects().getStandaloneCurves();
var filletFacc = moi.command.createFactory('fillet');
var filletFacToGetCorners = moi.command.createFactory('fillet');
filletFacToGetCorners.setInput(0, inputs);
filletFacToGetCorners.generateVertices();
var corners = filletFacToGetCorners.getCreatedObjects();
var segments = inputs.item(0).getSubObjects();
var startPoints = [];
for(k=0; k<segments.length; k++)
	startPoints.push(segments.item(k).getStartPt());
filletFacToGetCorners.cancel();
var cornersList = moi.createList();
for ( var i = 0; i < startPoints.length; ++i )
	if(isG0Connection(startPoints[i],corners)){cornersList.add( true );}
	else{cornersList.add( false );}
filletFacc.setInput(0, inputs);
filletFacc.setInput(1, false);
filletFacc.setInput(2, cornersList);
filletFacc.setInput(3, 1);
filletFacc.setInput(4, 'Circular');
filletFacc.setInput(5, 1);
filletFacc.commit();
moi.log("inputs: "+inputs.length+"\n");
moi.log("Corners: "+corners.length+"\n");
moi.log("cornersList: \n");
for ( var i = 0; i < cornersList.length; ++i ) {moi.log(cornersList.item(i)+"\t")};
moi.log("\n");
function isG0Connection(point, G0Points)
	var isSamePoint = false;
	for(j=0; j<G0Points.length; j++)
		if(point.x == G0Points.item(j).pt.x && point.y == G0Points.item(j).pt.y && point.z == G0Points.item(j).pt.z)
			isSamePoint = true;
			break;
		}else{isSamePoint = false;}
	return isSamePoint;
9581.378 In reply to 9581.377
Hi Mo,
can you make a node of your script please
I have very limited coding and will probably take forever.
Barry
Link on (various) Fillet node(s), and Chamfer node(s), from 2 and 4 years ago, with good information from Michael:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9666.1
(various Fillet and Chamfer nodes, are located in nodeeditor menus Curves2 and Construct2 menus. Some of them are probably not mature, fully functional nodes, and may need improvements from someone who knows what they are doing. And has understanding (?)) (Like grafting in MO-TE's code ?)
9581.380 In reply to 9581.379
I've just removed them from my nodeditor as Mo added new versions of fillet and chamfer edges into the construct menu.
I think a new thread maybe worth starting to filter out some of duplicate nodes and add new developed nodes that people want to share.
Anyway many thanks for your input.
Barry
9581.381 In reply to 9581.380
Thankyou Barry.
It seems that my nodeeditor, for this pc especially, is not up to date, with some "obsolete"/ defective nodes.
9581.382 In reply to 9581.378
Hi Barry
I was working on a new version of fillet node months ago, with ability to pick corner points directly from the scene, I guess I can add my new findings to it.
It's still buggy and I'm not sure when it'll be ready.
I'm not that skilled too. :)
9581.383 In reply to 9581.382
Hi MO_TE
Thank you for your hard work. You seem very skilled with the Javascript & Nodes.
I like the way that you break up Max's paragraphs of code into individual code lines. This tends to make them more comprehensible IMHO.
Is this "parsing" done by some editing software?
Notepad++ does not break down these code "paragraphs".
9581.384 In reply to 9581.382
Thanks Mo,
much appreciated.
Would be good to add fillet and chamfer to the curves section if possible.
Barry
9581.385 In reply to 9581.383
Hi Brian
Thanks, I wish I was. ;)
I use notepad++ with language set to JavaScript.
Maybe this helps you to format/beautify your codes:
https://beautifier.io/
9581.386 In reply to 9581.385
Thank you MO_TE for the JS-beautify link.
9581.387
"FilletCurve" and "ChamferCurve" nodes
Fillet/chamfer multiple curves at once.
You can choose a specific corner point to fillet or chamfer or set a pattern of 01 to fillet/chamfer curves.
How to use it?
Start nodeeditor and connect your curves to the node.
Click on the "FilletCurve" node to open the information panel.
In the "Select" dropdown menu choose the "sharp points" option.
This way you can see and choose the corner points in the scene.
When you finished picking corner points, choose the "Done" option from "Select" dropdown menu.
Also see the attached "FilletCurve_Showcase.nod" for an example.
Address:
Construct/FilletCurve
Construct/ChamferCurve
EDITED: 27 Jan 2024 by MO_TE
9581.388 In reply to 9581.387
Hi Mo,
Excellent will give them a try.
Many thanks
Barry
Excellent!
9581.390 In reply to 9581.387
Hi Mo,
quick update.
When filleting a selected object and applying the original object remains and cannot be deselected as normal (mouse click).
Perhaps keeping original is not needed.
Barry
9581.391 In reply to 9581.390
Hi Barry
Thanks for the bug report.
I've fixed the lock selection bug. Try updated version.
9581.392 In reply to 9581.391
Hi Mo,
works fine many thanks.
Barry
9581.393 In reply to 9581.387
In fact we must make our own schema from your example ?
(killing some nodes and save it ) that works fine...
Or there is an original somewhere ?
Or I miss something ?
(here in French for some nodes because i have French enable! :)
EDITED: 27 Jan 2024 by PILOU
9581.394 In reply to 9581.393
Hi PILOU
I modified my main.js to have more colors. But, there should be no difference in terms of working.
Actually, I was working on implementing some new features of this "litegragh" fork into the old nodeeditor. But, I haven't released it yet.
https://github.com/atlasan/litegraph.js
It works nice, But, I have some problems with html and css parts.
I was hoping to find someone interested/skilled to help me finish it! :)
9581.395 In reply to 9581.394
THx for the infos! And alas i can't help you on these difficult domains! :( (for me)
9581.396 In reply to 9581.387
MO,
RE: "FilletCurve" and "ChamferCurve" nodes
This is some impressive work. Indeed the facility for selecting vertices is such a profound contribution, that I really feel it is deserving of its own node.
As well as isolating vertices for fillet/chamfer operations, it could, for example add a trim point on a curve; and in the instance where there were coincidental end point, perform selective joining of curves; etc etc.
Also vertices could be output as points for the locating of other objects/geometry/vectors; or be the targets for operations (eg extrude to point).
Generally I am resistant to the tendency towards node library bloat, but in this case I believe that it would beneficial to take this facility for vertex selection out of your new nodes and universalise it into a dedicated node.
Either way; Brilliant work.
Keep it up.
PS Another thought: Could node have an "index" number array output as an alternative option?
EDITED: 28 Jan 2024 by JFH
Show messages:  1-16  …  317-336  337-356  357-376  377-396  397-416  417-425
