Node Wish List
 1-4  …  325-344  345-364  365-384  385-404  405-424  425
9581.365
not sure if there is a answer for this
Shown is a photo showing a square that as one corner already filleted.
When object is selected and crvfilllet node used to fillet the remaining corners
it produces the result on the right or fails.
Any ideas ?
Barry
9581.366 In reply to 9581.365
It looks like the node is trying to fillet points 4 and 5.
Is there a way to exclude the end points of the pre-existing fillet, from the new fillet?
Can the initial object be posted?
Would a join help?
Is there some way to identify all of the characteristics of the points?
EDITED: 21 Jan 2024 by BEMFARMER
9581.367 In reply to 9581.366
the node needs away of knowing if the point is G0.
If the curve is rebuilt it works fine but you end up with a lot more control points.
Barry
9581.368 In reply to 9581.367
Moi4 introduced a bunch of methods, tangents and derivatives...etc
9581.369 In reply to 9581.368
Here's a function for checking if a pair of curves is G1.
- Peer
// returns true if curve1 is tangent to curve2
function getCurvePairIsG1(curve1, curve2) {
    var curve1startPt = curve1.getStartPt();
    var curve1endPt = curve1.getEndPt();
    var curve1startTan = curve1.evaluateTangent(curve1.domainMin);
    var curve1endTan = curve1.evaluateTangent(curve1.domainMax);
    var curve2startPt = curve2.getStartPt();
    var curve2endPt = curve2.getEndPt();
    var curve2startTan = curve2.evaluateTangent(curve2.domainMin);
    var curve2endTan = curve2.evaluateTangent(curve2.domainMax);
    // flip one of the tangent vectors in the pair being compared for end-end and start-start cases
    var curve1startTanNeg = moi.vectorMath.createPoint(curve1startTan.x, curve1startTan.y, curve1startTan.z);
    curve1startTanNeg.scale(-1.0);
    var curve1endTanNeg = moi.vectorMath.createPoint(curve1endTan.x, curve1endTan.y, curve1endTan.z);
    curve1endTanNeg.scale(-1.0);
    var tol = moi.geometryDatabase.tolerance;
    // curve1 start curve2 end
    if (
        moi.vectorMath.distance(curve1startPt, curve2endPt) < tol &&
        moi.vectorMath.distance(curve1startTan, curve2endTan) < tol
        return true;
    // curve1 end curve2 start
    else if (
        moi.vectorMath.distance(curve1endPt, curve2startPt) < tol &&
        moi.vectorMath.distance(curve1endTan, curve2startTan) < tol
        return true;
    // curve1 start curve2 start
    else if (
        moi.vectorMath.distance(curve1startPt, curve2startPt) < tol &&
        moi.vectorMath.distance(curve1startTanNeg, curve2startTan) < tol
        return true;
    // curve2 end curve2 end
    else if (
        moi.vectorMath.distance(curve1endPt, curve2endPt) < tol &&
        moi.vectorMath.distance(curve1endTanNeg, curve2endTan) < tol
        return true;
    else {
        return false;
9581.370 In reply to 9581.368
Or for a planar joined curve you can use a G1 checker that's built into fillet factories. Search "GetCorners" in the API for an example of how to do that.
- Peer
9581.371
I tried to fillet a selected curve with code below.
It makes a list of "true" values for all corner points of the curve to fillet all of them.
Let's say I have a polyline consists of two segments and one corner point.
Logically, the corners List should be like this : {true}
This approach works on closed curves like a rectangle, but, fails on open curves. I need to add an extra "true" value to the list for open curves to work.
Also it fails on open and closed curves with an existing fillet or non "G0" continuity.
Like the one Barry showed in (9581.365)
Am I missing something?
script:
var inputs = moi.geometryDatabase.getSelectedObjects().getStandaloneCurves();
var filletFacc = moi.command.createFactory('fillet');
var filletFacToGetCorners = moi.command.createFactory('fillet');
filletFacToGetCorners.setInput(0, inputs);
filletFacToGetCorners.generateVertices();
var corners = filletFacToGetCorners.getCreatedObjects();
filletFacToGetCorners.cancel();
var cornersList = moi.createList();
if(inputs.item(0).isClosed)
for ( var i = 0; i < corners.length; ++i ) {cornersList.add( true );};
}else
for ( var i = -1; i < corners.length; ++i ) {cornersList.add( true );};
filletFacc.setInput(0, inputs);
filletFacc.setInput(1, false);
filletFacc.setInput(2, cornersList);
filletFacc.setInput(3, 1);
filletFacc.setInput(4, 'Circular');
filletFacc.setInput(5, 1);
filletFacc.commit();
moi.log("inputs: "+inputs.length+"\n");
moi.log("Corners: "+corners.length+"\n");
moi.log("cornersList: \n");
for ( var i = 0; i < cornersList.length; ++i ) {moi.log(cornersList.item(i)+"\t")};
moi.log("\n");
9581.372 In reply to 9581.370
Hi Peer,
Your code and reference look to be superb solutions.
At this time, I have too many projects, and too little time and energy, to work on this.
( Not to mention limited ability :-)
9581.373 In reply to 9581.371
Hi Mo,
Re: Am I missing something?
Is there a specific problem with the script, aside from the needed extensions that you list, or are you asking about the general approach?
One general potential problem is that the input currently accepts a list of curves, but it seems like the cornersList approach will only work for a single joined curve.
Also, filleting behaves differently if the input is 2 curves: it tries to mutually extend the curves and connect them with a fillet segment even though the input curves aren't G0.
- Peer
9581.374
Hi All,
Just to add to my previous post.
This issue does not happen if done manually with moi fillet tool.
So perhaps Michael can shed some light on the issue.
Anyway Brian’s crvFillet node woks fine with open / closed and 3D curves.
Brian
is it possible to comment out the select input ?
I tried but didn’t work.
Many thanks
Barry
9581.375 In reply to 9581.373
Hi Peer
I wanted to keep it simple, this code is supposed to work just on a single curve.
I know I can fillet corner points of a curve, using a list of true/false values.
What I don't understand is why it won't work on for example an open curve with one corner point. (a V shape curve)
It actually needs a list of two (or more?) to work, while the generateVertices() method returns one vertex.
9581.376 In reply to 9581.375
Also since v4 there is this function on curve segments:
Added CurveSegment.getIsG1ToAdjacentSegment( 0 /* 0 for start, 1 for end */ );
- returns true if the next segment at the start or end is smooth to the current curve segment.
9581.377 In reply to 9581.376
So, I found my mistake on fillet factory.
I thought the corners list's length should be equal to length of points generated by "generateVertices()" method.
But, It seems it should be equal to segments count.
That's why fillet node generates that curly effect in Barry's screenshots. It tries to fillet all corner points including the "G1" corner points
I just filtered the real "G0" points out of all corner points (segments start points).
script:
var segments = inputs.item(0).getSubObjects();
var startPoints = [];
for(k=0; k<segments.length; k++)
	startPoints.push(segments.item(k).getStartPt());
for ( var i = 0; i < startPoints.length; ++i )
	if(isG0Connection(startPoints[i],corners)){cornersList.add( true );}
	else{cornersList.add( false );}
moi.log("\n");
function isG0Connection(point, G0Points)
	var isSamePoint = false;
	for(j=0; j<G0Points.length; j++)
		if(point.x == G0Points.item(j).pt.x && point.y == G0Points.item(j).pt.y && point.z == G0Points.item(j).pt.z)
			isSamePoint = true;
			break;
		}else{isSamePoint = false;}
	return isSamePoint;
9581.378 In reply to 9581.377
Hi Mo,
can you make a node of your script please
I have very limited coding and will probably take forever.
Barry
Link on (various) Fillet node(s), and Chamfer node(s), from 2 and 4 years ago, with good information from Michael:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9666.1
(various Fillet and Chamfer nodes, are located in nodeeditor menus Curves2 and Construct2 menus. Some of them are probably not mature, fully functional nodes, and may need improvements from someone who knows what they are doing. And has understanding (?)) (Like grafting in MO-TE's code ?)
9581.380 In reply to 9581.379
I've just removed them from my nodeditor as Mo added new versions of fillet and chamfer edges into the construct menu.
I think a new thread maybe worth starting to filter out some of duplicate nodes and add new developed nodes that people want to share.
Anyway many thanks for your input.
Barry
9581.381 In reply to 9581.380
Thankyou Barry.
It seems that my nodeeditor, for this pc especially, is not up to date, with some "obsolete"/ defective nodes.
9581.382 In reply to 9581.378
Hi Barry
I was working on a new version of fillet node months ago, with ability to pick corner points directly from the scene, I guess I can add my new findings to it.
It's still buggy and I'm not sure when it'll be ready.
I'm not that skilled too. :)
9581.383 In reply to 9581.382
Hi MO_TE
Thank you for your hard work. You seem very skilled with the Javascript & Nodes.
I like the way that you break up Max's paragraphs of code into individual code lines. This tends to make them more comprehensible IMHO.
Is this "parsing" done by some editing software?
Notepad++ does not break down these code "paragraphs".
9581.384 In reply to 9581.382
Thanks Mo,
much appreciated.
Would be good to add fillet and chamfer to the curves section if possible.
Barry
Show messages:  1-4  …  305-324  325-344  345-364  365-384  385-404  405-424  425
