Node Wish List
 1-16  …  217-236  237-256  257-276  277-296  297-316  …  417-425
9581.257 In reply to 9581.256
Here are the differences between the two results.
The command line keeps all the objects together.
The NE code takes all the solid objects and separates them.
Size: 263.7 KB, Downloaded: 100 times, Dimensions: 828x497px
Size: 293.8 KB, Downloaded: 95 times, Dimensions: 493x413px
9581.258 In reply to 9581.256
Hi Wayne, inputs for the ExplodeMove factory go like this:
Index 0 : "Objects" - object list of objects to explode.
Index 1: "Scale factor" - numeric value for scale factor.
Index 2: "Origin" - optional origin point for scaling.
9581.259 In reply to 9581.258
Thank you for the quick reply. The input parameters you provided are as expected. This leads to additional code is required to filter the objects types and keep the closed objects together. Back to coding...
Thank you,
Wayne
Draft of a 3D log spiral node.
For 2D, set zFactor to zero.
This is just an alpha version with little testing.
I want to add arcLength output...
(Code came from powerConeSpiral script.)
9581.261 In reply to 9581.257
Ok, I had to do some deep searches for an answer to my problem. Found the solution to my objects exploding in a rarely referenced documentation by Max Smirnov.
Here he explains the essence of the multi-Process syntax for a node setup:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
My solution is to simply add a + to the Long mode so the array is processed as one element.
Wow, Thank you Max for that post!
Wayne
9581.262 In reply to 9581.261
Final result of solution:
Size: 2.3 MB, Downloaded: 117 times, Dimensions: 649x586px
9581.263 In reply to 9581.261
Good find Wayne.
Was wondering what Lont+ meant.
(I did read that post by Max 5 years ago, but never really grasped it.)
Did a slight upgrade of alpha logSpiral node.
But see that Karsten? already did a curve length node.
So (at least some?) MoI curves have a .length property, so I do not have to re-calculate the arcLength...
image host
EDITED: 13 Mar 2022 by BEMFARMER
9581.264 In reply to 9581.262
Cool adaptation! :)
9581.265
My old experiments.
Size: 404.1 KB, Downloaded: 98 times, Dimensions: 1701x939px
9581.266 In reply to 9581.265
Cool try! :)
As per Barry's suggestion, here is a kludged together Macro, using the Concat node, renamed, to enable the creation of a macro node with several lines of text.
Highlight the completed text macro in the nodeeditor canvas, and EXPORT it to the Macro directory, with desired name.
Saving it saves the DocText macro as a node program, so Loading it with Load erases the current canvas screen.
The DocText macro may be entered into a new screen through the right click Macro menu.
Do NOT get the DocText macro with the Load button.
The Macro menu seems to lack a scrolling bar, so space may be limited???
This whole Macro Save vs Export vs Load, versus macroLoad is confusing. There should be a SaveMacro button, and a LoadMacro button? And Macro scroll?
Also, every node Program would need to have its own text macro saved???
Well it is an experimental kludge...I cannot spend any more time on it.
I'm sure Max could do something really good...
image host
(Deleted this old attachment, for space)
EDITED: 17 Jan 2025 by BEMFARMER
A few simple tests:
It seems that only one master DocText Macro is needed.
The Macro can be right click MacroSelected to the canvas multiple times, and each canvas copy can have its text modified in different ways, and the canvas .nod program saved in a node program.
But the modifications permute the order of the text lines, which is not good.
Edit: Macro Import can import the DocText file from some other directory.
Note, the order of the text lines can be changed by Max' addition a few years ago of the ability to Alt+Drag the input Dots to the Macro. (I had forgotten this.)
EDITED: 16 Mar 2022 by BEMFARMER
9581.269 In reply to 9581.268
Brian & Barry,
Litegraph.js the foundation for NodeEditor contains a "Panel" node (see image below),
which I imagine is for notes within a node circuit. Unfortunately it does not appear to be functional.
Litegraph demo can be found here:
https://tamats.com/projects/litegraph/editor/
9581.270 In reply to 9581.269
Thank you James.
So I finally found the WidgetPanel code here:
litegraph.js zip is at github.
litegraph.js-master>src>nodes>interface>WizardPanel().
It states "Non interactive panel".
So my guess is that it is just a pretty box, which does not have any text ability. (???)
There are a couple of other programs using litegraph, that may use the box, with additions, to display graphics(?)
EDITED: 17 Mar 2022 by BEMFARMER
9581.271 In reply to 9581.270
There is a LiteGraph used in blokist.gitlab.io, but I cannot find out where to download it. gitlab site does not recognize blokist.
9581.272 In reply to 9581.270
Brian,
Sorry, only include the cascading menus in the image in my last post
to reveal the location of "Panel" node. I should have checked that each tier
of the activated menu items remained highlighted: Add Node/Widget/Panel
The other element in litegraph demo that would be useful in NE is "Add Group"
Groups may be individually named and nodes are within the group border can then
be moved around the canvas as a block.
9581.273
not sure if it's been mentioned before but the ability to name objects that then appear in Moi object list would be useful.
I am creating mechanisms with one nod then automating with another nod to check for clashes. So the get by name node
would automatically pick the objects if this was available.
Barry
9581.274 In reply to 9581.1
L-System Node
Some time ago I became excited by the potential of the Lindenmayer rewriting system for pattern generation in nodeEditor.
The wikipedia page offers a decent explanation:
https://en.wikipedia.org/wiki/L-system
Initially I was thinking of a pair of nodes: a) universal rewriter & b) a interpreter/turtle node. This is the common approach and the one that Grasshopper has taken. However, I realised that the lack of facility for handling string data would render this method impractical, and so shelved the idea.
That was until today when I discovered this website:
https://onlinemathtools.com/l-system-generator
The images above are all examples of patterns generated with this online tool, and could potentially be generated in NE with parametric control.
The page is rich in javascript, including one linked files called "l-system-generator.js" which I wonder if it may present a template for
the authoring of a NE node following a similar approach. Many of the options on the webpage would not be needed in the node.
Link for javascript file:
https://onlinemathtools.com/js/bridges/l-system-generator.js?v=2dcf9b
Below I have shown a proposal for a L-System Node. It need only have inputs for the Starting point, the number of generations, the line length for branches, the branch angle and scaling factor of line length of branches of each generation. For the 6 patterns shown above the "Scale/Gen" value would be 1, but botanical structure such shown below would have a decimal value < 1 (eg 0.3).
All of the grammatical formulation would be located in the info panel. I have included outputs as lines and as well as points because each has advantages.
I know that this would likely be a major undertaking, but if there are any biters, I do believe it was be an amazing contribution to NE.
Have a great weekend,
PS this page may also be of interest:
https://jsxgraph.org/wiki/index.php/JavaScript_code_for_producing_Lindenmayer_systems
EDITED: 31 Mar 2022 by JFH
9581.275 In reply to 9581.274
for complete ;)
https://www.youtube.com/watch?v=JFugGF1URNo&list=PLRqwX-V7Uu6bxNsa_3SfCPyF9Md9XvXhR
and look on the right of the page of links!
9581.276 In reply to 9581.274
James, a cool project, (for someone with time:-)
Is the js code for the algorithm(s) downloadable from the site?
I do see lots of code in page source...
fern is in the MoI forum.
Free Book:
http://algorithmicbotany.org/papers/abop/abop.pdf
Show messages:  1-16  …  197-216  217-236  237-256  257-276  277-296  297-316  317-336  …  417-425
