Node Wish List
 1-10  …  211-230  231-250  251-270  271-290  291-310  …  411-425
9581.251 In reply to 9581.250
Yes Node approach is interesting :-)
However, I do not have Rhino at the moment and I love MOI over other CAD modelling tools. So, I think I will wait (for developers to develop more features on Nodeeditor)
And thank you for your reply.
9581.252 In reply to 9581.251
Else you have this free Nodes prog online :)
https://cables.gl
9581.253 In reply to 9581.252
Interesting! and this online Nodes prog could export too?
9581.254 In reply to 9581.253
I suppose yes! ;)
"Easily export your piece of work at any time. Embed it into your website or use it for any kind of creative installation."
EDITED: 18 Jan 2022 by PILOU
9581.255 In reply to 9581.254
Ok, thank you for the link.
9581.256
I am attempting to simulate the Explodemove of two Voroni patterns extruded as Pilou's demo below, but with a new node on the NE (node editor, elephant some call).
Ref:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10470.4
The problem that is happening with my NE code is, everything is exploding when it should stay as a solid when moved.
If the objects are defined and applied, then the explodeMove is executed from the command line, it works fine.
The factory API for explodeMove is being guessed at by trial and error. Mostly error.
factory('explodemove', objects, distance, point);
Is there an additional parameter that says to keep the objects solid and not explode?
Thank you,
Wayne
EDITED: 11 Mar 2022 by WAYNEHILL5202
9581.257 In reply to 9581.256
Here are the differences between the two results.
The command line keeps all the objects together.
The NE code takes all the solid objects and separates them.
Size: 263.7 KB, Downloaded: 100 times, Dimensions: 828x497px
Size: 293.8 KB, Downloaded: 95 times, Dimensions: 493x413px
9581.258 In reply to 9581.256
Hi Wayne, inputs for the ExplodeMove factory go like this:
Index 0 : "Objects" - object list of objects to explode.
Index 1: "Scale factor" - numeric value for scale factor.
Index 2: "Origin" - optional origin point for scaling.
9581.259 In reply to 9581.258
Thank you for the quick reply. The input parameters you provided are as expected. This leads to additional code is required to filter the objects types and keep the closed objects together. Back to coding...
Thank you,
Wayne
Draft of a 3D log spiral node.
For 2D, set zFactor to zero.
This is just an alpha version with little testing.
I want to add arcLength output...
(Code came from powerConeSpiral script.)
9581.261 In reply to 9581.257
Ok, I had to do some deep searches for an answer to my problem. Found the solution to my objects exploding in a rarely referenced documentation by Max Smirnov.
Here he explains the essence of the multi-Process syntax for a node setup:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
My solution is to simply add a + to the Long mode so the array is processed as one element.
Wow, Thank you Max for that post!
Wayne
9581.262 In reply to 9581.261
Final result of solution:
Size: 2.3 MB, Downloaded: 117 times, Dimensions: 649x586px
9581.263 In reply to 9581.261
Good find Wayne.
Was wondering what Lont+ meant.
(I did read that post by Max 5 years ago, but never really grasped it.)
Did a slight upgrade of alpha logSpiral node.
But see that Karsten? already did a curve length node.
So (at least some?) MoI curves have a .length property, so I do not have to re-calculate the arcLength...
image host
EDITED: 13 Mar 2022 by BEMFARMER
9581.264 In reply to 9581.262
Cool adaptation! :)
9581.265
My old experiments.
Size: 404.1 KB, Downloaded: 98 times, Dimensions: 1701x939px
9581.266 In reply to 9581.265
Cool try! :)
As per Barry's suggestion, here is a kludged together Macro, using the Concat node, renamed, to enable the creation of a macro node with several lines of text.
Highlight the completed text macro in the nodeeditor canvas, and EXPORT it to the Macro directory, with desired name.
Saving it saves the DocText macro as a node program, so Loading it with Load erases the current canvas screen.
The DocText macro may be entered into a new screen through the right click Macro menu.
Do NOT get the DocText macro with the Load button.
The Macro menu seems to lack a scrolling bar, so space may be limited???
This whole Macro Save vs Export vs Load, versus macroLoad is confusing. There should be a SaveMacro button, and a LoadMacro button? And Macro scroll?
Also, every node Program would need to have its own text macro saved???
Well it is an experimental kludge...I cannot spend any more time on it.
I'm sure Max could do something really good...
image host
(Deleted this old attachment, for space)
EDITED: 17 Jan 2025 by BEMFARMER
A few simple tests:
It seems that only one master DocText Macro is needed.
The Macro can be right click MacroSelected to the canvas multiple times, and each canvas copy can have its text modified in different ways, and the canvas .nod program saved in a node program.
But the modifications permute the order of the text lines, which is not good.
Edit: Macro Import can import the DocText file from some other directory.
Note, the order of the text lines can be changed by Max' addition a few years ago of the ability to Alt+Drag the input Dots to the Macro. (I had forgotten this.)
EDITED: 16 Mar 2022 by BEMFARMER
9581.269 In reply to 9581.268
Brian & Barry,
Litegraph.js the foundation for NodeEditor contains a "Panel" node (see image below),
which I imagine is for notes within a node circuit. Unfortunately it does not appear to be functional.
Litegraph demo can be found here:
https://tamats.com/projects/litegraph/editor/
9581.270 In reply to 9581.269
Thank you James.
So I finally found the WidgetPanel code here:
litegraph.js zip is at github.
litegraph.js-master>src>nodes>interface>WizardPanel().
It states "Non interactive panel".
So my guess is that it is just a pretty box, which does not have any text ability. (???)
There are a couple of other programs using litegraph, that may use the box, with additions, to display graphics(?)
EDITED: 17 Mar 2022 by BEMFARMER
Show messages:  1-10  …  191-210  211-230  231-250  251-270  271-290  291-310  311-330  …  411-425
