Node Wish List
 1-4  …  205-224  225-244  245-264  265-284  285-304  …  425
9581.245 In reply to 9581.244
"Could we have a search ability within Nodeeditor?"
That's all that's implemented.
Size: 118 KB, Downloaded: 97 times, Dimensions: 1051x1010px
9581.246 In reply to 9581.245
Dear WN,
Yes I have already seen that but I meant something like search ability inside blender3D ( I don't know if you have seen it or not)
Inside Blender3D if you press F3 (a default hotkey for search within Blender3D) I meant something like that! (And I know it may sound a bit odd but somehow I miss that ability when I work with Nodeeditor)
9581.247 In reply to 9581.246
Psygorn, I agree with you but there is no such thing in this program.
9581.248 In reply to 9581.247
ok, :-)
But could it be made for it? because this thread is called "Node Wish List"
9581.249 In reply to 9581.248
Hi Psygorn,
I would think that it's possible if someone dedicates a lot of time and effort on it.
At the moment it's not really being actively developed by anyone so it's not too likely though.
9581.250 In reply to 9581.248
If you like the node approach to making geometry you might want to check out the Grasshopper system in Rhino, it's more mature and has more dedicated development resources on it.
9581.251 In reply to 9581.250
Yes Node approach is interesting :-)
However, I do not have Rhino at the moment and I love MOI over other CAD modelling tools. So, I think I will wait (for developers to develop more features on Nodeeditor)
And thank you for your reply.
9581.252 In reply to 9581.251
Else you have this free Nodes prog online :)
https://cables.gl
9581.253 In reply to 9581.252
Interesting! and this online Nodes prog could export too?
9581.254 In reply to 9581.253
I suppose yes! ;)
"Easily export your piece of work at any time. Embed it into your website or use it for any kind of creative installation."
EDITED: 18 Jan 2022 by PILOU
9581.255 In reply to 9581.254
Ok, thank you for the link.
9581.256
I am attempting to simulate the Explodemove of two Voroni patterns extruded as Pilou's demo below, but with a new node on the NE (node editor, elephant some call).
Ref:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10470.4
The problem that is happening with my NE code is, everything is exploding when it should stay as a solid when moved.
If the objects are defined and applied, then the explodeMove is executed from the command line, it works fine.
The factory API for explodeMove is being guessed at by trial and error. Mostly error.
factory('explodemove', objects, distance, point);
Is there an additional parameter that says to keep the objects solid and not explode?
Thank you,
Wayne
EDITED: 11 Mar 2022 by WAYNEHILL5202
9581.257 In reply to 9581.256
Here are the differences between the two results.
The command line keeps all the objects together.
The NE code takes all the solid objects and separates them.
Size: 263.7 KB, Downloaded: 100 times, Dimensions: 828x497px
Size: 293.8 KB, Downloaded: 95 times, Dimensions: 493x413px
9581.258 In reply to 9581.256
Hi Wayne, inputs for the ExplodeMove factory go like this:
Index 0 : "Objects" - object list of objects to explode.
Index 1: "Scale factor" - numeric value for scale factor.
Index 2: "Origin" - optional origin point for scaling.
9581.259 In reply to 9581.258
Thank you for the quick reply. The input parameters you provided are as expected. This leads to additional code is required to filter the objects types and keep the closed objects together. Back to coding...
Thank you,
Wayne
Draft of a 3D log spiral node.
For 2D, set zFactor to zero.
This is just an alpha version with little testing.
I want to add arcLength output...
(Code came from powerConeSpiral script.)
9581.261 In reply to 9581.257
Ok, I had to do some deep searches for an answer to my problem. Found the solution to my objects exploding in a rarely referenced documentation by Max Smirnov.
Here he explains the essence of the multi-Process syntax for a node setup:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
My solution is to simply add a + to the Long mode so the array is processed as one element.
Wow, Thank you Max for that post!
Wayne
9581.262 In reply to 9581.261
Final result of solution:
Size: 2.3 MB, Downloaded: 117 times, Dimensions: 649x586px
9581.263 In reply to 9581.261
Good find Wayne.
Was wondering what Lont+ meant.
(I did read that post by Max 5 years ago, but never really grasped it.)
Did a slight upgrade of alpha logSpiral node.
But see that Karsten? already did a curve length node.
So (at least some?) MoI curves have a .length property, so I do not have to re-calculate the arcLength...
image host
EDITED: 13 Mar 2022 by BEMFARMER
9581.264 In reply to 9581.262
Cool adaptation! :)
Show messages:  1-4  …  185-204  205-224  225-244  245-264  265-284  285-304  305-324  …  425
