Node Wish List
 1-12  …  193-212  213-232  233-252  253-272  273-292  …  413-425
9581.233 In reply to 9581.171
Where is "ExtendSrf.js" to be found?
9581.234 In reply to 9581.233
Hi Psygorn.
9581.235 In reply to 9581.234
Hi WN,
Thank you.
I cannot find "Loft2.js" as well. Where can I find it?
9581.236 In reply to 9581.235
Maybe try a search for +mLoft2 ?
9581.237 In reply to 9581.236
Hello bemfarmer,
I am sorry I thought mLoft2 is different from Loft2, my bad!
your reply helped me :-) thank you.
9581.238 In reply to 9581.231
Helloo bemfarmer,
I ran into a problem:
What should I do now?
I looked for vector3D.js and I did not find it!
9581.239 In reply to 9581.238
Vector3d.js should be in the extension folder (?)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.217
Program of WayneHill.
9581.240 In reply to 9581.239
Thank you,
But I ran into a new error!
Which makes me confused! I thought it should be working by now!
I have qhull3d.js in extensions folder of nodeeditor.
9581.241 In reply to 9581.240
Strange results...
Note that the number of points input to the qhull need to be 3 or more, and should be an integer, (not
having a decimal point.) Otherwise, on two computer systems, home and work, the slider behaved weirdly, with mouse motion above or below the slider,
the slider would move, and weird exceptions occured. With 3+ integer number of points, the slider works fine.
So set the slider minimum to 3, and have no decimals, in its info box.
Getting your error sounds strange.
9581.242 In reply to 9581.241
I asked James directly about the problem however, I'd be happy if you take a look at it too.
you can find the .nod file here: https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.466
9581.243
Here are my latest versions. Yes, the original Voronoi conversion was limited to 100 objects. Updated to 1000.
Wayne Hill
9581.244
Hello all,
Could we have a search ability within Nodeeditor? (like blender when we press F3 a search window pops up)
Also when doing right-click to find a node could we have the opened windows open until we click on empty space?
9581.245 In reply to 9581.244
"Could we have a search ability within Nodeeditor?"
That's all that's implemented.
Size: 118 KB, Downloaded: 97 times, Dimensions: 1051x1010px
9581.246 In reply to 9581.245
Dear WN,
Yes I have already seen that but I meant something like search ability inside blender3D ( I don't know if you have seen it or not)
Inside Blender3D if you press F3 (a default hotkey for search within Blender3D) I meant something like that! (And I know it may sound a bit odd but somehow I miss that ability when I work with Nodeeditor)
9581.247 In reply to 9581.246
Psygorn, I agree with you but there is no such thing in this program.
9581.248 In reply to 9581.247
ok, :-)
But could it be made for it? because this thread is called "Node Wish List"
9581.249 In reply to 9581.248
Hi Psygorn,
I would think that it's possible if someone dedicates a lot of time and effort on it.
At the moment it's not really being actively developed by anyone so it's not too likely though.
9581.250 In reply to 9581.248
If you like the node approach to making geometry you might want to check out the Grasshopper system in Rhino, it's more mature and has more dedicated development resources on it.
9581.251 In reply to 9581.250
Yes Node approach is interesting :-)
However, I do not have Rhino at the moment and I love MOI over other CAD modelling tools. So, I think I will wait (for developers to develop more features on Nodeeditor)
And thank you for your reply.
9581.252 In reply to 9581.251
Else you have this free Nodes prog online :)
https://cables.gl
Show messages:  1-12  …  173-192  193-212  213-232  233-252  253-272  273-292  293-312  …  413-425
