Node Wish List
 1-5  …  166-185  186-205  206-225  226-245  246-265  …  406-425
9581.206 In reply to 9581.205
If one cycle has occurred, setting hz[0] == 0 should stop the if loop (?).
Would a trigger input be of any use?
Here is an incomplete draft quartz3 node, untested.
Place in nodeeditor extensions node, to add to basic2 menu.
(More code needs to be added/modified.)
EDITED: 8 Aug 2020 by BEMFARMER
9581.207 In reply to 9581.206
OK, here is the draft quartz3 node. It is incomplete.
There has been no time for testing. It is loadable in nodeeditor under MoI4.
The theory is that the Cycle Once node uses most of the same code as the Cycle Continuous node, except that when it gets to the end the first time,
the value of hz[0] is set to 0. Tic-toc Once mode has not been coded for. Cleanup has not been done.
9581.208 In reply to 9581.207
quartz2 and quartz3 make the piston work in motor.nod from 2017.
Cycle Once does not terminate. v1 just keeps getting changed. The code needs to be changed.
When v1 = end, the if loop should be exited?
Message 9581.209 deleted 14 Aug 2020 by JFH
9581.210 In reply to 9581.209
edgesNums Node
The proposed node would parse input surfaces & output a numArray of the number of sides of each item.
It could be used together with logic/compare & split nodes to isolate surfaces of a designated number of sides.
(I have only included an "Out" output, to reduce the tedious need for Object/Clone node prior.)
EDITED: 14 Aug 2020 by JFH
9581.211
vecLerp node
The proposed node would generate new vector that is a linear interpolation between 2 input vectors.
See this link for clear explanation:
https://p5js.org/reference/#/p5.Vector/lerp
9581.212 In reply to 9581.211
Michael's randomize script defines two simple Lerp functions.
function Lerp( low, high, t )
	return low + (high-low)*t;
function RandLerp( low, high )
	return Lerp( low, high, Math.random() );
Wikipedia has a more accurate return formula, for floating point. (?)
Need to define Lerp function for vectors, (x, y, z points).
Linearly interpolate between vector v1, and vector v2.
lerpVectors ( v1, v2, interpolationFactor )
v1 - the starting vectpr.
v2 - the vector to interpolate towards.
interpolation factor, typically in the closed interval [0, 1].
So regular javascript does not have a lerp function (?)
So the 3d lerp function must be defined in terms of simpler javascript commands.
Found 2d lerp function here:
https://www.redblobgames.com/grids/line-drawing.html
1d: function lerp(start, end, t) {
    return start + t * (end-start);
function lerp_point(p0, p1, t) {
    return new Point(lerp(p0.x, p1.x, t),
                     lerp(p0.y, p1.y, t));
Note: to do 3d vector lerp, add
 lerp(p0.z, p1.z, t)
to the redblob code.
(Use vectorLerp() (?))
This vectorLerp is a bit confusing...negative numbers? low > high, clamping t? angleLerp vs quaternionLerp, floating point problems...
But I think that this proposed node is relatively easy to do, once understood.
Then smooth motion Move of an object could be done...
t is usually between [0, 1], but does not have to be.
negative t might be a problem?
Negative low and high, and low > high might be problems?
A good link: https://danielilett.com/2019-09-08-unity-tips-3-interpolation/
EDITED: 16 Aug 2020 by BEMFARMER
9581.213 In reply to 9581.212
Significant editing was done to prior post.
Due to limited understanding of Lerp, it might be best to write the node, then worry about what if
negative numbers are used, clamping is needed, or vector1 x1, y1, z1 coordinates vs vector2 x2, y2, z2 coordinates are not always low...high, or ?.
9581.214 In reply to 9581.213
Do regular value Lerp with math node(s).
Do vectorLerp with a nodeeditor Macro?
Brian
9581.215 In reply to 9581.213
Draft of a Lerp macro for number values.
Partial draft of a LerpVector node for v1 = (x1, y1, z1), v2 = (x2, y2, z2).
It uses pairs x1 and x2 for a and b inputs to one of three copies of the Lerp macro. Similarly for y1, y2 and z1, z2.
The three X, Y, Z outputs are the resulting interpolated vector.
The c input is the interpolation factor, == t, normally from [0 to 1]. Use slider widget?
So a vector could have its X, Y, Z split out...? (For v1 and v2)
untested.
The javascript code of the existing vector nodes, versus the pointarray datatype are nearly incomprehensible for myself :-)
I went back to some of the old posts by Max and Karsten, about the pointarray data structure, and its 10 elements,
and wrote up some documentation, but still do not understand a lot...
With a slider input to c, the node works, but there seems to be a scale factor of 2, somehow.
See next post for two macros and node.
EDITED: 19 Aug 2020 by BEMFARMER
9581.216 In reply to 9581.215
Here is an updated LerpVectorMacro, which can be placed in the Macro folder, along with LerpMacro.
Also is the node program using the two macros, lerpVectorTest2 node.
2X "scale" bug still present.
The LerpVectorMacro contains 3 copies of the LerpMacro.
To save a macro, (for example LerpMacro), export LerpMacro from the canvas to a folder, naming it LerpMacro.nod.
Then copy the file LerpMacro.nod to the nodeeditor macros folder, for future re-use.
Similarly for LerpVectorMacro.nod, or any other Macro.
9581.217
New qhull3d Node:
Based on the qhull library:
https://github.com/bjnortier/qhull
http://www.qhull.org/
I would like to thank James for helping out with testing.
Save all the files to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Input:
1. Points: At least three points to start the node.
Outputs:
1. Triangles: Line edge vectors to create planar faces.
2. Hull Pts: The outer most points of a point cloud being input.
3: Hull Pts Objects: The outer most object points of a point cloud being input.
Added a new Vector3d.js point class function for future projects.
Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
What is the the name of a "qhull" : a polyhedron ?
9581.219 In reply to 9581.218
Qhull computes the convex hull from points.
https://en.wikipedia.org/wiki/Convex_hull
The attached image is a simple point cloud. Red spheres are the outer-most points of the cloud making up the hull. The lines are the triangles that make up the outer-most planes of the hull.
9581.220 In reply to 9581.217
WOW,
I dabbled a few years ago, but gave up.
Brian
Now to try it with spherePts...
9581.221 In reply to 9581.217
This link explains, in simple terms, the difference between static methods and instance methods,
in particular for a vector class. Its examples with PVector (from processing), essentially show how to use the Vector3d.js class. (FALSE)
https://www.khanacademy.org/computing/computer-programming/programming-natural-simulations/programming-vectors/a/static-functions-vs-instance-methods
Note, after much confusion, the PVector examples are different from the way Vector3d is written.
So this post should be disregarded. The classes can be written in different, conflicting ways.
EDITED: 12 Jan 2021 by BEMFARMER
9581.222 In reply to 9581.221
Brian,
Thank you! Max uses the Vector class on his Subdivide and the Cloth script. It was used on the original qhull source code.
Wayne
9581.223 In reply to 9581.222
Thank you Wayne.
I'll look at those other programs.
I have been puzzling over how to do add-on libraries, and how they are "linked", or accessed.
There seems to be multiple ways to write code.
It seems like nodeeditor/Javascript scans all the addons.
Would having ES6, (or ES11?), be of any benefit?
-Brian
9581.224 In reply to 9581.223
Brian,
MoI's WebKit interface determines what resources are available for the Node Editor uses to ensure stability. My Javascript version is 1.7. ES6 or ES11 would more likely be on a different environment like a backend server Node box. The Node Editor startup scans the scripts and begins the background services. The scripts are scanned and linked in their filename order.
loadScripts('core', 'lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes', 'macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs', '*');
loadScripts('nodes/extensions', '*');
loadScripts('core', 'init, ext.*');
If you want to build a library calling other Javascript files, they have to be scanned (note filename order) before they are available for the other libraries to use.
Example directory:
1test.js
2test.js
3test.js (uses 1test.js and 2test.js and 4test.js)
4test.js
3test.js can use 1test.js and 2test.js libraries but not 4test.js library because it has not been scanned. Error will trigger on a missing script. It is not missing.
4test.js will have to be renamed to 0test.js in both 3test.js and it's filename.
New listing:
0test.js
1test.js
2test.js
3test.js (uses 1test.js and 2test.js and 0test.js)
Wayne
9581.225 In reply to 9581.224
Thank you Wayne.
It is very useful information.
Show messages:  1-5  …  146-165  166-185  186-205  206-225  226-245  246-265  266-285  …  406-425
