Node Wish List
 1-12  …  133-152  153-172  173-192  193-212  213-232  …  413-425
9581.173 In reply to 9581.172
More like an additive and retraction of the face edges without changing location. Michael described it as a surface offset.
EDITED: 17 Jan 2021 by WAYNEHILL5202
9581.174 In reply to 9581.173
Excellent!
9581.175
Hi All,
It is a bit of an unusual method, but using Wayne's new node,
and using a sphere as a starting point, it's possible to form a compound
curved surface of the shell of a chair.
Thanks Wayne for your most recent contribution.
I'm hoping that coding nodes is a good technique to staving off cabin fever,
& we are it beneficiaries.
EDITED: 17 Apr 2020 by JFH
That's magical thing!
9581.177
BranchStructure node
The proposed node would generate venation patterns from seed points branching out to leaf points (attractors) using the "space colonization" algorithm.
Daniel Shiffman has done a coding challenge that serves as a good introduction to the method:
https://www.youtube.com/watch?v=kKT0v3qhIQY
Another good resource is Jason Webb's "Modeling organic branching structures with the space colonization algorithm and JavaScript" :
https://medium.com/@jason.webb/space-colonization-algorithm-in-javascript-6f683b743dc5
He demonstrates the difference between "Open versus closed venation" which is an option I have include in the info panel. The other option I have included is 2D vs 3D. 3D would work similarly, however with branches attracted to leaf points in 3d space, making possible the generation of natural forms such as tree, coral etc. This may be something that is left for later development.
EDITED: 1 May 2020 by JFH
9581.178
Hi All,
I have already alluded to this here:http://moi3d.com/forum/index.php?webtag=MOI&msg=9810.10 but in terms of implementation, rather than the generalised approach it may be better to have a purpose built "Reaction Diffusion" node.
React-Diffusion node
I am proposing a node that operates analogous to online app by @pmneila https://pmneila.github.io/jsexp/grayscott/
For our purposes the output would only need to be black and white, which hopefully would reduce the complexity of the coding. The proposed node would, similarly to Wayne's imgSampler convert greyscale to heightmaps, however instead of importing an image, it would be generated via an algorithm (grayscott) within the node.
Since this algorithms produce an evolving animated image there is a need to pause evolution at a desirable point so I have included an input for 1 to play & 0 to pause. There may be a more elegant solution of the inclusion of menu option in the info panel, or perhaps ideally a button on the node, itself.
I'm not sure if this is even possible without the addition of external js libraries. (I note that in the code for the online app link above that it imports three.js)
EDITED: 24 May 2020 by JFH
9581.179 In reply to 9581.178
Viewing page source yields: https://github.com/pmneila/jsexp
9581.180
Playing with a new node conversion of Max Smirnov's cloth script that he converted from the ThreeJS engine.
http://moi.maxsm.net/files/scripts/
My first attempt in animation on the Node Editor. Much to learn from Max's script.
9581.181 In reply to 9581.180
Does it works now with any volumes and not only a sphere ?
9581.182 In reply to 9581.181
Only spheres are in the original code. Will be testing other geometry types.
9581.183
Added node form and javascript code to message:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.180
9581.184
Finally releasing my ImgRGB first mentioned here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.165
The rgbquant.js library limits the style layers on the image.
ImgRGB send an RGB connection to OutRGB to reassemble the image to the style layers.
The OutRGB node only works with the ImgRGB node.
Thank you to James for the on going testing of the nodes I keep sending him... :-)
Wayne
Message 9581.185 deleted 14 Jun 2020 by JFH
9581.186 In reply to 9581.182
Wayne,
The cloth node is fantastic.......and mesmerising to watch.
"Only spheres are in the original code.
Will be testing other geometry types".
Although no doubt, working with other shapes would be usualful, I think your time would be better spent with the inputting of anchor points. This facility is included within Max's cloth script.
Anchoring points makes it possible to generate tent structure by setting gravity to a negative number:
I wonder if it would be easier to define, if instead of a rectangle input as you now have, it worked with a point array input (ie with MathsPoints or Points node input) In this way, the cloth point density is externally defined and anchor points selected with idSelect node.
Anyway, I know that this is no easy task, & what you done is just brilliant, I am just think about how this functionality may be integrated into the node ecosystem for procedural modelling.
Great work
EDITED: 14 Jun 2020 by JFH
9581.187 In reply to 9581.186
James,
Yes, the anchor points are a part of the code. I was excited to see the first conversion drop cloth running, it was released for testing before setting up anchor points option. Negative numbers, great tip.
A point array would work since Max is converting the plane to a grid point array. That would skip a step.
Wayne
9581.188 In reply to 9581.187
Wayne,
"A point array would work since Max is converting the plane to a grid point array. That would skip a step."
Ideally both the geometric data input and output would be point arrays, so that they delineate curves or polylines in U&V directions. Whereas curves may be lofted or networked, polylines could be polylofted. I know that this has presented difficulties with other nodes (ImgSampler), so if it is only possible to output curves, this would still be fantastic.
"Negative numbers, great tip."
Ahh! Negative gravity: this was the underlying methodology behind Gaudi's Sagrada Familia
http://www.ipernity.com/doc/jacquespfjc/13188615
Looking forward to the next beta
9581.189 In reply to 9581.188
James,
Added the anchor index point numbers of the grid array. No error checking...
You have negative gravity :-)
Left in the error checking "file.writefile()" outputs I use to watch the program flow.
Still working on the grid array input.
Wayne
9581.190 In reply to 9581.189
Cloth2.js must be inside the folder
Moi\nodeeditor\nodes\extensions\ ?
9581.191 In reply to 9581.190
That is correct. It is still a beta program.
Wayne
9581.192 In reply to 9581.189
Thanks Wayne,
The addition of anchor selection is a great advancement.
Did you have a look at using a point array instead of a plane
as the input?
I don't know if Max'x code would even allow it, but it would
really be something, if anchor points could be dynamically
manipulated (re-positioned), with the effect of stretching &
tugging the fabric.
It hints at great promise.....
very exciting
Show messages:  1-12  …  113-132  133-152  153-172  173-192  193-212  213-232  233-252  …  413-425
