Node Wish List
 1-13  …  94-113  114-133  134-153  154-173  174-193  …  414-425
9581.134 In reply to 9581.132
Thanks James thats great - is it possible to put a node in to control spacing between circles and maximum and minimum hole size this could be a very valuable tool in the creation of laser cut screens. Regards Alex. Here is a job I completed several years ago I used Grasshopper to achieve similar results.
Nice result! What was the material ? (Metal, wood, cement...)
9581.136 In reply to 9581.134
Alex,
Just to be clear, my post for proposal of "geoPack" node, was just a proposal, not the contribution of a new node. That would be the task of someone more skilled in coding than I.
But to answer your question: the node for controlling min & max radii would be ArrayExt/reRange node (as it happens, this is one of the few nodes that I have actually contributed).
However to achieve a result similar to the images shown, with equi-spaced holes of various sizes, you would simply link you close-packed circle pattern to construct2/offset & apply the desired offset to each circle.
PS The screen looks great BTW.
What is this building? In Sydney? it's OK i found it
EDITED: 30 Jan 2020 by JFH
9581.137 In reply to 9581.134
That's some really cool artwork Alex!
9581.138 In reply to 9581.130
Hi James,
Re:
> I've always believed that NE was the same for both v3 & v4,
> but if it doesn't work for you with v3, then perhaps not.
I seem to remember that there is one thing that doesn't work in v3 which is Macros. I think it's something like it assumes it's installed in the appdata folder but v3 doesn't have the appdata support for that.
It's this one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1494
Hopefully Max will see this to take a look.
Sometimes i have this mysterious 16 who appears ! ?
who seems the same than the PerlinNoise Node ?
9581.140 In reply to 9581.139
It was a minor coding error on the original release. It was discovered and quickly fixed hoping nobody noticed :-) Missing one bracket...
Download the latest files from this link.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.105
I am sorry about that. The programs are usually tested before release into the wild. That one got away.
Wayne
9581.141 In reply to 9581.140
No problem! :)
9581.142
There has be some recent discussion regarding chamfering in NE: http://moi3d.com/forum/index.php?webtag=MOI&msg=9666.1 , so it would seem opportune to propose a new node:
Chamfer Node
The proposed node is analogous to Chamfer UI tool. Michael has outlined the chamfer factory inputs here: http://moi3d.com/forum/index.php?webtag=MOI&msg=9666.11
The node would be input with a polyline and output with Chamfers applied.
The "ptSel" input would operate similarly to "Mask"input on Logic/Split node, so that alternate points are selected by inputting 1,0 or 0,1. Entering 1 would select all points.
Moreover, the "ptSel" input could be any combination of 1s & 0s, as that in the example of a 5 pointed star, may be a string of 10 comma separated numbers of any order (eg 1,1,1,0,0,1,0,1,0,0)
"Dist1" and "Dist2" are the chamfer ends offsets from point. Of course, in many instances "Dist1" and "Dist2" will have the same input.
Have a great weekend
EDITED: 3 Feb 2020 by JFH
9581.143 In reply to 9581.142
Perhaps a version for breps (solids), and a version for edges, and the curve version...
Or maybe one version can do it all. Input would be an objectlist, not limited to breps...
9581.144 In reply to 9581.143
Brian,
>> Perhaps a version for breps (solids), and a version for edges, and the curve version...Or maybe one version can do it all. <<
Probably it would be better to have multiple versions, but encapsulated into a single "Chamfer" node.
9581.145
Further to the discussions here: http://moi3d.com/forum/index.php?webtag=MOI&msg=9666.1
Fillet Node
The proposed node would operate analogous to "Fillet" UI tool. Instead of selecting points to apply rounding, the node would be multi-processing and would operate on each point; however the radius may be 0 and hence that corner would remain un-rounded.
A single numeric input into "Radi" would applied the same rounding to all corners, where 2 comma separated inputs will apply alternate radii (as shown in image below with "Radi" input of "10,0" ). Of course more complex patterns of numbers may also be entered
A great weekend to all
9581.146
Extrude2 Node
The proposal is to extend the functionality of Extrude node to include the other options of "Extrude" UI tool.
Extrude2 Options
Vector: multiprocessing vector input give magnitude and direction.
Tapered Mode (positive & negative angles, converge & diverge respectively) If this could have vector input all the better.
To Point Mode
EDITED: 1 Feb 2020 by JFH
A Dual Slider widget node would be useful.
There is a Demo of such a slider here: https://refreshless.com/nouislider/
and a link to GitHub download.
(So this might be an easy project? Maybe not. There is a lot of code)
There are some install instructions here: https://stackoverflow.com/questions/4753946/html5-slider-with-two-inputs-possible
I have not had time to see if it would be compatible with nodeeditor and MoI.
There would be a min value, a max value, and "p_value" slider, "grip" and "q_value" slider "grip".
min <= p_value <= q_value <= max. (I would also like 2 < q_value.)
For my Doyle Spiral Node, if I ever finish it.
EDITED: 16 Feb 2020 by BEMFARMER
9581.148 In reply to 9581.147
Brian,
Do you mean something similar to Widget/Range node? See below.
Or something altogether different?
EDITED: 16 Feb 2020 by JFH
9581.149
Polygon Edge Node
This node would be analogous to Draw/Polygon/Edge UI tool.
Although initially it could be a standalone node, ideally it would be a 2nd option to Curves/Polygon node, as shown.
The resultant polygon would be defined by inputting 2 points and the number of sides.
There could be a "Flip" Mode with pulldown menu choice of "True" & "False", but there could be some utility in allowing these options to be set dynamically. For example an input of 0,1 would draw 2 polygons back to back.
9581.150 In reply to 9581.148
Hi James,
Yes, the range node is close.
I have just been making some minor modifications, for a range2 node.
Not quite there yet.
9581.151 In reply to 9581.150
Two connected sliders would work well.
The p slider would range in integers, from 1 to max_value, and could not exceed the current q slider value.
The q slider would range in integers, from 3 to max_value, and could not be less than the current p slider value.
This is possible, saw an example on the internet.
9581.152
Rectangle2 Node
This one is pretty self evident. The proposal is not a new mode as such, but rather an extension to the existing Curves/Rectangle node, to include rectangle by 2 points and by 3 points options.
9581.153
CloseCrv Node
The proposed node would close open curves, analogous to Michael's CloseCurve script: http://moi3d.com/forum/index.php?webtag=MOI&msg=2752.2
Also the node could have secondary function of check which of the input curves are closed or not, outputting a numArray of 1s and 0s.
EDITED: 21 Mar 2020 by JFH
Show messages:  1-13  …  74-93  94-113  114-133  134-153  154-173  174-193  194-213  …  414-425
