Install NodeEditor in MoI
All  1-6  7
9462.7 In reply to 9462.5
Hi Jose,
I've been having fun/frustration re-installing everything, using my hazy memory :-)
For MoI3, For the "Light" colored version of nodeeditor, a second hotkey can be created with the following command:
moi.ui.createDialog( 'nodeeditor/index.html?scheme=Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
I really like the Light version.
I'm using hotkery Ctrl+Alt+M for the light version, and
Ctrl+Alt+N for the standard "dark" version.
ps, If you are installing for MoI4beta, I see that you have the nodeeditor directory up two folder levels from where it should be.
The Path is .....AppData\Roaming\Moi\nodeeditor. (Windows 10)
For MoI4beta the hotkey script agrees with the one you showed. There is also a light version of a hotkey.
Please specify if you are using MoI3, or MoI4beta.
In Windows 10 file explorer, I created a Library link straight to ...Roaming/Moi, for quick access to the AppData information for MoI4Beta, and nodeeditor files, such as Macros and node extensions...
EDITED: 11 Aug 2019 by BEMFARMER
Show messages: All  1-6  7
